Buddy MK1
(In Topic #165792)
1983 Pirelli Edition
I started a couple of threads on other forums so thought I would copy my progress so far over to here.
I use to own a mk4 golf gti which I built up to this stage:
The mk4 was a great daily and served me well for a good few years but I felt I had taken it as far as I wanted to so stripped it for parts and purchased a new daily and a new project.
The new project is a 1983 mk1. It came with a 16V lump in it, mk2 leathers and some banded steels. I made the trip down from Kent to Bridgewater to pick it up and the drive home was brilliant. Drove well and sounded great. Initial plans were to simply tidy it up, find a nice set of wheels and deck it. It had already had some work done to it including a full respray, new wings, sills, and front end. I was offered some turbo its in p/x for the banded steels so before I knew it I had an engine build on the c ards aswell. I then set about removing the 16V inlet manifold and the 4 branch exhaust manifold to make way for the turbo bits. These includ ed T3 Turbo, Turbo manifold, 16V/ 20V inlet manifold with AGU TB, 20V fuel rail and injectors, and a front mount. I then got a little distracted away from the engine and started gutting the interior. This included seats out, carpet out and remove all the original sound deadening (which took TIME) Once the bulk of it was out I cleaned it up with some thinner, repaired a few areas which were rusty and applied some zinc primer. The passenger footwell has rusted badly where it met the sill so I bought a replacement panel and ditched the rusty one. The replacement panel is pretty thin in comparison to the original material so I tried to keep as much original metal as possible. While working on the inside I also put in some sound proofing. I work for an AV installation company and we use Silent Coat in some of our speaker boxes which works really well so I decided to use it in the mk1 aswell. The doors, rear arches, roof have been done so far and I will be doing the footwells and the boot floor later on. This stuff really is impressive. I cant wait so see how much it reduces the road noise.
1983 Pirelli Edition - http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=view&id=165792
The plastic backs were pretty beaten up so I pulled them apart and retrimmed them in a suede/ alcantara material. I think the result will help to make them look more at home and not too put of place. It certainly helps to date them slightly.
I initially didnt cover the airbags but after refitting them it was obviously that they would need to be covered aswell
The base panels will also be trimmed once I find some spare time.
As the bay was empty it would have been rude to just put the 1.8T in there and not tidy it up a little so out came the battery tray, off came the brake servo, MC and balance bar, off came all the seem sealer, and all the unwanted holes are being welded up. Im new to a lot of this kind of work so its taken me quite a bit longer that it would most.
In between working on the bay and interior, I started to tidy up the new engine. All unwanted items were stripped off, 16V tensioner, new waterpump, cambelt, custom engine mount, and a lick of paint.
1.8 non turbo cam cover
New carpets
New headliner Downpipe flange etc
Good luck getting her finished off.
Smudger
Matt
Scott - not that I know of but it may well have been. I found it through eBay
i want to do the same with the crackle paint on my block- what did you use to do it ? and also it looks like you pianted it with normal paint first then did the crackle ?
Design Manager
2018 Up! GTi 1.0 TSI
2011 Caddy Maxi Kombi 1.6 TDi
Marketing Manager
Can't wait to see this finished
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Had a good weekend on the car. Finished stripping the underside back to bare metal. one of my rear beam studs snapped when removing it so I cut it down, drilled it out and dropped a new bolt in from the top. There is a handy little slot inside the car which is nearly directly above the studs. I dropped the bolt in and welded around the head to keep it in place. once secured I trimmed it down to match the others. Last night I managed to get the last of the underseal sprayed. I always manage to get more on me and in my hair than I got on the car lol. I also managed to start getting the front control arms, hubs and suspension back on. I had the control arms, rear beam, ARBs and a few other bits powdercoated. Iv also fitted super pro bushes. Its nice to see parts finally going back on. Hoping to have him back on the ground within the next week or two.
Nice job
Matt
I managed to get the rear arb on the rear beam last night. The arb brackets are such a pig to fit but I got there in the end. They went on a little wonky but a bench vice straightened things out. The rear beam is now back on the car and Im hoping to put the stub axel and disc assembly back together tonight. Can offer up the rears then. Cant get enough of these
I am blown away by your skills!
Oh I nearly forgot, a very warm welcome to the Club.
