1.5 Engine Timing
(In Topic #165550)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/mmmmmmmmmmmmmmm.jpg)
![LeonSmith in the usergroup ‘Local’ LeonSmith in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
heres a mk2 flywheel for comparison, big diamond is btdc smaller punch id tdc:
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Fflywheelmark.jpg)
worst case a long pokey implement down sparky #1 and turn it over till its at the top! just be sure you dont get the implement wedged. the piston is at the top for a few degrees, you need to divide this by 2 if you want true tdc but tbh the movement is so small you should get away without having to do this. The smallest unit of adjustment on the belt is 1 tooth after all!
![:dry:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/dry.png)
