Why won't it start properly? (KR 1.8 16v conversion)
(In Topic #164347)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
![Pistolpete75 in the usergroup ‘Newbie’ Pistolpete75 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Running rough when starting
Have had all the fuel lines and pump changed, have changed spark plugs, but no other electrics(apart from re wire from crazy quiffs) has an Abf dizzy leads etc all the same from when I bought it, will be changing all this soon. So are there any pros that could point me in the right direction please.
Kr and abf have different dizzys and Kr lets you adjust the ignition timing and this could be part of your problem.
Is it running on standard Kr (k-jet) or abf management?
Also what work have you had done?
My Kr wouldn't run right down to the metering head. If you have a spare injector, you can take an injector out of cylinder 1 with hose attactched, bung a apsare injector in the cylinder and see if the injector is working correctly. And repeat this for all four cylinders.
Have you had a compression test (or is it rebuilt?)
I have just changed all 4 injectors and pipe work, but still doing same thing as before. I have had all fuel lines inc pump from what I have been told also I think the accumulator has been changed but will be checking with garage. I thought it was fuel related but could be electrical, I have changed spark plugs but that is all the electrical side apart from a re wire. Really bugging me now.
