Lemon Yellow Tin top Restoration
Get the yellow out!!
watson said
Top work as always Andrew. Nice tidy and clean workshop you have there.
Thanks very much. I must confess though, the workshop is my dads, the car will be back over to mine once it is sprayed
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
Neil_Ireland said
Nice to see another lemon yellow being put back on the road Mine is in primer.
Yeah I cant wait
Its been a joint effort so far, between me and my dad, and my mate sandblasting it, but its coming along nicely nowRonnie85 said
Always impressed how fast your getting through this! Looking forward to seeing paint Get the yellow out!!
Rear chassis legs repaired
Spare wheel well repaired
New lower rear panel fitted
Started to fill the new arch
Rear quarter panel in primer
Primed the rear and stone chipped the bottom of the panel
Drivers side quarter panel and sill in primer and stone chipped the sill
Any surface rust was when the cars was been worked on was removed with a wire brush in the grinder back to bare metal, then zinc primed, seam sealed and stone chipped
First coat of high build on the roof
Not bad going. I still need to prime and seam seal the front panel, engine bay and inside then its a case of more rubbing down then some nice new Lemon Yellow paint
watson said
Looking good. Interested to know if your going to do the underside and wheelarches black or bodycolour lemon yellow.
Thanks. Underside and the wheel arches will be sprayed lemon yellow
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
mazza411 said
Great work so far, I hope to do this one day to mine, can I ask what the black stuff you've sprayed on the floor is? and where you got your arch repair panels from? Matt
Thanks. The black is stone chip. I got my repair panels from http://www.vwheritage.com/
Changed my mind and sprayed the underside and arches black.
Melteddrummer said
Car is looking great! not long for the rebuild then?
Thanks very much I'm hoping it will be somewhere near finished by the end of September.
