mk1 Golf G60 Intercooler/radiator options
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/7avatar.jpg)
![Rich. in the usergroup ‘Paid Member’ Rich. in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Rich. in the usergroup ‘Local hero’ Rich. in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
paul_h said
it fits really well are you going to use a header tank or going for the topfill rad ?
I will probably go top fill as I want to keep the engine bay nice and uncluttered
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
RichG said
Hi Ade,
Your head sounds good. Is it complete?
Ive heard that the head bolts are a different size for 1H heads. Will I need to get the block machined to accept the different bolt size?
Otherwise im on the look out for a pg head.
Yes it is complete.
The bolt holes are m11 instead of m10 - to be honest I am not sure if you can just bolt it onto a PG block with m10 bolts.
Website Manager
Looking around a few of the forums it appears that a 1h head will go straight on a PG block due to the locating pins being the same, you then just use the bolts to match the block.
http://www.dubforce.net/forums/index.php?showtopic=24236
The other way around is possible too, and is in fact what had to be done to my 16v head to put it on a 1h block ie bore the heads bolt holes out.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/rsz_null_zps87eca6a6.jpg)
![paul_h in the usergroup ‘Old timer’ paul_h in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
here is a topfill with merc intercooler
![](https://vwgolfmk1.org.uk/uploads/pbextract/1334351/14112009104.jpg)
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
What exhaust manifold are you using?
