Guy's Rivage
Guy's Rivage
jobs done for MOT - new brake lines as old ones were shot and new injection unit from a rado as it failed on emissions, was adjusted, passed and then wouldn't run.
since MOT and driving it.
on another thread I was having problems with the brake lights not working, fixed these through changing out the fuse in the fuse box (twice), decided to go the whole hog and completely refresh the fuses in the fuse box.
fuse box before by Guy Frankland, on Flickr
fuse box after by Guy Frankland, on Flickr
had a little crack at the drivers door card.. it had three problems. the leatherette was coming away from the card, the handle kept on falling off and the speaker cable was earthing and causing an error on the radio.
interior in need by Guy Frankland, on Flickr
so, door card off, speaker cable sorted, plates made up for door handle grommits… then epoxied to the door… they ain't coming off! then reattached the leatherette and glued and stapled it in all the right places…
door card by Guy Frankland, on Flickr
not 100% happy with it so might revisit when I sort the passenger door card out.
the poppers on the tonneau cover were either missing or looked rubbish so I replaced them all… haven't taken an after shot yet but this is the state it was in before…
I can now drive down the road with the top down and not worry that it is going to ping off at any moment!
replaced the pedal covers with some cheapies I bought from ebay.. not too impressed with them but better than the ones that were falling off
did a little clutch adjustment today as there was too much travel and started to have a little tinker in the engine bay, just some odd jobs, cleaning washer jet contacts and wiper blade contacts… now spray much stronger and appear to wipe faster!
found that the airbox wasn't closed properly… must have been the garage.. now sorted.
next up, service, door cards and roof repair and refit rear carpet once I know it is watertight again. then repair and repaint the seats.
Just keep at it matey and it will soon come right. Like you say it just takes time.
I have some spare material for the roof if you need it. Under and over patch till your ready for a new one.
chortle said
Good news on the brake light issue Guy.
hi carl
that sounds tempting… I purchased some from ebay but I want to create almost a second skin on the rear 'panel' where the window is so that it looks almost complete and not 'patchy' - the material on that entire section is pretty fubar really - how much are you thinking ok £ wise? pm me if you like?
ran some wynns engine cleaner through the system
popped it up onto a chuff ramp
Chuff ramp by Guy Frankland, on Flickr
drained it and replaced the oil filter
replaced the air filter too, the old one was orrible
New and old air filters by Guy Frankland, on Flickr
tightened up the rocker gasket as that appeared to be leaking somewhat
gave the bay a clean, not perfect and needs a lot more work!
Engine clean by Guy Frankland, on Flickr
also replaced the MFA stalk as the original was knackered.. the MFA selector had sprung out of the stalk and was determined that it wasn't going back in!
Mfa stalk replacement by Guy Frankland, on Flickr
MFA still isn't working on the dash though… will have to have a read up on it… unless anyone has any specific suggestions?
have obtained some hardboard for the door card replacement - hope to get around to cutting them out to template, waterproofing them and building them up with the original components from the existing cards.
pleased to say it was…
Interior cleaned by Guy Frankland, on Flickr
added a bit of sound deadening
Sound deadening applied by Guy Frankland, on Flickr
and then popped it all back together and added a sticker - and as we all know a sticker like this adds +5bhp
Golf mk1 forum sticker by Guy Frankland, on Flickr
Currently Mk1less!
Currently Mk1less!
smudger said
Nice work Guy. Engine bay is getting there. Going to look proper good when finished mate. Keep up the good work
thank you
if only there weren't so many goddam wires and cables going everywhere!! Does anyone have any examples of a GTi engine bay that has been, erm, simplified.
i'm also using this thread MK1 Golf GTI - Engine Detailing | Detailing World Forum as a bit of inspiration… although I don't think i'll get there just yet!!
as usual it's been a while! have just serviced with oil change, coolant flush, new fuel filter, spark plugs, HT leads, dizzy cap and rotor arm
have also just correction detailed but will wait till other bits are done before posting pics!
added new genuine hella headlights but am really, really, struggling to find genuine inner spots 😕 (want in new/A1 condition)
have had a problem with rough idle but found the source of the air leak and done a temporary fix for the moment.
more to come…
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
also replaced the little rubber outer ring on the rear boot lock today… i've been meaning to do it for ages and it looks so much better!
ive got alot of grafting before mine gets to that standard
loved reading all the updates
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
Work on my Clipper
jez said
VERY nice Rivage ! Ever thought of putting 3 point seat belts in the back?
cheers Jez… I did think about it a few years ago when I was with someone that had a small person… but I don't have any kids myself and there is hardly any time when people go in the back now and I am trying to keep things standard.
popped a new starter motor today in as the last one went ping last wednesday, had the usual kerfuffle with ECP and the wrong part but got the right one today.
Looks like the front engine mount is shot… at least what I think is the front engine mount… sits with the starter motor bolts through it? Will check in the engine section.
replaced the plastic seat runners and handle bushes… i had ordered these thinking that I could find a home for them but I couldn't - any ideas if I should be able to find a home for them?
also added top rad card thanks Shugy then started on an engine bay clean as a camshaft oil seal leak made a bit of a mess last year!
