cabriolet roof and frame removal
(In Topic #153530)
![hitty in the usergroup ‘Regular’ hitty in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
anyone know how to remove a roof
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/matrix.jpg)
COTM Team
![aircooled1968 in the usergroup ‘Local hero’ aircooled1968 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
now with the access there are 10mm nuts on a cable, this is the rear tension cable, undo this with spanner (ratchet wont fit) and remove cable on both sides, lift roof back up but dont fasten it down, you will notice some 17mm bolts, 3 on each side (i think) remove em all, get a mate to help lift roof off as its heavy.
last bit, grab a beer and put tools away. Hope helps
COTM Team
Cabriolet Hood Replacement - The Mk1 Golf Owners Club
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/38image.jpg)
![Edgey72 in the usergroup ‘Local’ Edgey72 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mark
COTM Team
![vacabrio in the usergroup ‘Newbie’ vacabrio in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
COTM Team
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/9B01F95F-54C9-45F4-841E-14770AF6160F.jpeg)
![Tango788 in the usergroup ‘Regular’ Tango788 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
COTM Team
Tango788 said
Has anyone got a photo how to do on removal of the roof?
follow this link it has all you need, just take pics to hel you as you go along
![scraf in the usergroup ‘Regular’ scraf in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
aircooled1968 said
its quite simple, drop the roof for access, remove rear seat (base and back), remove the rear door cards (i know there is no door lol) you now have access to the self tappers that hold the covers on, remove the the press button and the plastic covers, you now have access to the bolts, whilst roof is down and the tennsion has gone, go into the boot and under the shelf supports there are some bent over clips, straighten those up (be careful they sharp pointy things), remove roof fabric from clips under shelf support.
Thanks for this, drinking a beer right now after sucessfully removing a decent top and frame at a scrapyard today.
Tools needed were spot on, 10mm, 13mm and 17mm spanners, a socket set came in handy, but not necessary.
One hickup though, the 10mm nuts attached to the cable that hold the roof down at the rear, they wouldn't come loose, the cable twisted as opposed to the nuts loosening.
Sorted it with a pair of long nose vice grips on the end of the cable, hope this helps someone in the future.
