16v kr conversion wiring loom
(In Topic #133625)
I havnt got a clue how to wire up the kr engine loom into the fuse box, or where to connect the new wires to as my car wasnt equiped with the systems origionally.
Alternatively, If somebody is competent at doing a quality job of making me a complete loom up from my existing loom, and kr loom I would consider it an option.
Any help is greatly appreciated.
Kind regards
Kris
I have a list of wires that are confusing me as to where they go, where to connect them to or what to do with them.
The kr ecu has a 3 way female connector coming from it, the colours of the 3 wires which go into it are black/yellow, red yellow and black/white.
On the distributer side of the cylinder head next to the water pipe outlet there are 3 male spade connectors and a brown plastic connector I am not sure what wires connect to them or what they are for.
From the origional wiring loom there are some wires that used to go to the 1.3 cylinder head, i'm not sure if I can connect these to the equivalent sensor on the kr head? or what exactly the sensor was they connescted to, they are, solid black, blue/black, yellow and yellow and red.
There is a single push on nipple looking connector on the rear of the kr head behind the distributer, i'm not sure what this sensor is or what wire connects to it.
And finally there is a male 2 pin connector on the kr airbox and another the same on the throttle body I need to wire in to somewhere but I'm not sure how to connect these into my cars fuse box, if thats where they connect to.
Its all one big learning curve for me and I really do appreciate your help
no big deal pretty simple conversion to do. got a full wiring diagram here:
Google Sites: Sign-in
what you can do is strip both looms down then keep all the mk1 sensor wiring for dash temp, oil pressure etc and just swap the kr engine stuff over. you'll have to mess with the wire lengths in places though since the mk2/rado has the fusebox on the opposite side of the car.
if you really get stuck i can do the loom conversion for you
What would be your price? What would you need?
What do mean by swap the kr engine stuff over? Where do I connect up the lives for the ecu, tci and fuel pump etc…
I'm lost?
Do you know what colur wires from the origional loom are for what eg oil pressure etc.
then you have a mk1 sensor/wiper loom, and a mk2 engine loom. combine the 2 using my wiring diagram above, all sorted!
the wiring you need to get it to run is very minimal, just the coil wires and everything from the ecu. the extra complexity comes from the isv controller, but even that is easy since its pretty much self-contained, just a couple live and earth feeds to get it going.
last hurdle is the cold start parts, but again only 2 wires to the fusebox!
to make a mk1/2/3 based loom i charge £90, and to do it i need the old loom plus the donor loom
So, where do I find the live feed for eg for the 2 lives to the tci and ecu?
And say for another example the connector that connects to the kr throttle position where will that go?
Also the kr oil cooler has a spade connector on top of it and another one sat an ich behind, where would I connect these up to as my origional carbu loom didnt have these?
Also do you know anything about the 3 spade connectors and brown plastic connector I mentioned earlier that are on the dizzy side of the cylinder head???
Regards
Kris
the 3 on the side of the head are temp sensors for dash, ecu and isv control unit, you'll see all of these in the diagram
I know that you said its all on the diagrams but I'm struggling a little with them tbh, the 3 wires I mentioned that come from the tci/ecu bit.
There are 3 wires. one red/yellow, one Black/yellow and 1 black/white. Do you know where I connect these to?? As I have followed them back and the other ends connect into the old corrado connecter which plugged into the corrado fusebox, and I think one went into a relay? But i'm cluecless as to where to connect them to on my mk1 fuse box.
And also, the water oil cooler housing has One spade connector ontop of it and another 1 an inch behind it but I cant find which wires connect on to these? Any ideas buddy?
Kris
black/yellow goes to the idle switch and the isv control unit, this goes live when throttle is closed
red/yellow is the fuel pump relay earth trigger, goes to pin D/13
water/oil cooler housing are the oil pressure switches, on the 1.3 these are on the back of the head. depending on the age/spec of your car you may have only had 1 oil pressure switch, so only 1 wire to hook up.
you'll need to chop out the old MK1 coil + wire from D23, as this is a resistance wire for the old points ignition coil. you need to replace this with a normal chunky wire. it will be a bit tricky to do this, use a thin screwdriver to release the 2 locking pegs on the pin and remove it, cut all the wire off and solder your replacement wire on.
when i make these looms i have a pile of old fusebox plugs i can strip for parts, so i steal the needed wiring from these.
When you say the red/ yellow wire goes to pin d/13, is that on my mk1 fusebox?
Also, I noticed that there is a blue plastic connector on the fuel rail on the kr. It has a black wire coming from it, the black wire has a female spade connector splitting in it and then carries on to another plastic connector I think plugs onto the Airbox. Any idea where the black wire should connect to? I appologise for all the questions, there is so much I need to know and it's becoming a bit of a guessing game.
Thanks again
kris
D/13 on your mk1 fusebox yes, there may be a purple/black wire here for the carby, if not you'll either have to use a k-jet pump relay or find a spare CE1 loom to strip for spare pins, with the small ones i just cut the plugs up with a sharp knife to get the pins out. the large ones are easy to remove using a thin watchmaker screwdriver.
the blue plug is for the 5th injector, and the black spade wire goes to the 2nd spade connector on the k-jet starter motor. the other wire goes off to the cold throttle enrichment valve. you can see this on the 1st picture in the kr wiring diagram, the 5th injector is labled N17, and the cold throttle enrichment is F93. starter motor is labled B
Wiring
The black wire I have coming from the 5th injector( which I presume is officially called a cold start valve) via the starter motor I have going to something the diagram calls a vacuum timeswitch? I don't know if that where I connected it to but I plugged it onto somthing bolted to a bracket on the rear of the metering head that has a v small pipe coming into it at the other side.
Does all this sound normal so far?
Regards
the vacuum switch is the metal thing behind the 16v airbox, the larger black plastic one is the over-run cutoff valve, this connects direct to the isv control unit and an ignition live feed.
thermal switch wire is probably jsut an ignition live feed, which if so will come in handy for soem of the things you need to power up for the 16v loom. you need an ign live to the idle switch, the overrun cutoff and the isv control unit
Where is the over run cut off valve, and isv control and the idle switch?
Also, I have a green/red single spade connector which close to the 3 connectors on the side of the cylinder head, is that where it connects? The other end connects into a relay that was part of the corrado loom as do some of the other wires.
green/red spade is temp sensor for the isv control unit, it goes to oneof the 3 sensors on the side of the head. the relay you mentioned on the corrado loom is the isv control unit, you need this as well as the loom between it and the 2 white plugs behind the fusebox!
What's the component on the dizzy side of the head that has 2 wires connected to it and some pipes, 1 of which runs along the front of the head and back towards the airbox? I'm just curious.
Also, with regards to the coil, there is a green wire coming from the ecu, I presume it has to connect to the coil, and a black wire coming from the ecu aswell. But on the corrado loom it has a red/black wire which looked as though it should connect too. How should I wire it up?
Regards
kris
thats the WUR, controls the fuel mixture
red/black is for the rev counter, green is the trigger signal wire from the tci/ecu to fire the coil. both of these wires go to the coil -ve. there is also another red/black wire to the coil -ve from the isv control unit, which has a spade connector which you unplug when setting the base idle.
the +ve side of the coil is where the 2 black and the black/white wires go
