DX to ABF conversion wiring
![crezz in the usergroup ‘Local’ crezz in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
the red and brown are probably live and earth for the diagnostics port, if so tap them into the ciggy lighter or wherever is easy
I guess its easiest to splice the grey/white into the green.. what about the yellow then though? esp if I don't have the jumper block?
that just leaves the green from immob to connect to the port, and yellow and grey/white to go?
ive got my fuel pump relay (167) which will be replacing the (60) relay, it will fit in but pin 85 is in a different location?
all ive got left to do is red plug to e14 spade?
few issues which I think is down to the fuel pump relay as the fuel pump just keeps priming with ignition on, I may of missed something though, the fuel pump is being powered off a gti loom, should this be correct or should I of done something else?
as it stands d/13 is yellow/blue running into engine bay, that's all, is this wrong?
where or what is the ecu relay earth trigger?
managed to sort the fuel pump priming, not sure how but it stops as it should though, still wont start though, the idle control valve seems to be crackling, think that's whats blowing fuse 17?
![Avatar](https://img.photobucket.com/albums/v260/shaggyjh/SERVER/VR6%20Mk1%20Golf/smallavatar_zpsb20946d3.jpg)
![vrupper in the usergroup ‘Local’ vrupper in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I'll try and pop up Saturday.
fuse 17 is an ignition live feed so its possible its feedign the coil, if so check the wiring behind the engine to the tps and idle switch it gets baked by the exhaust and cracks up. you'll note there is another 2 pin plug with a black and brown wire, this is for the breather heater and is on the same feed as the isv so if it shorts out it'll kill the isv fuse. you can just chop all the wiring out for it as its unused in the uk.
