20vt conversion, un-pleasant noises when turning left- CV joint?
(In Topic #162284)
![thickfreakness in the usergroup ‘Local’ thickfreakness in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1329942/7AE66EB7-69EA-4F27-81AF-58C9394DCA18-21720-000008C31DC678D8_zps708ee07a.jpg)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi46.tinypic.com%2F2wnuwz9.jpg)
![higher1 in the usergroup ‘Local’ higher1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
If so i would say your shaft is to long i had the same problem which ended up breaking the inner cv joint any vibrations when driving slight wobble at all?
I cant remember what the drive shafts are from. Im running an 02a box if that makes any difference. There 100mm shafts though
The cheapest way is to fit a mk 3 polo diesel shaft just the shaft use your inner and outer cv joints
Your shaft should be approx 535 long the polo shaft will be 515
Are the likes of scirrocco and mk1 driveshafts the same length?
I spent hours looking through tech specs on shafts etc pretty sure the lupo and polo ones are the only ones shorter than yours polo has same splines both ends etc as yours / cabby shafts ie 100mm cups
My friend also running a 20v turbo using just caddy mounts etc has the same problem as I had since lowering it the shaft is to long
