Fitting a 02a gear stick and cables into a mk1
(In Topic #159919)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20120812_110741.jpg)
![13craig13 in the usergroup ‘Local’ 13craig13 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Im currently in the process of putting an ABF engine with the 02a gearbox, from a seat ibiza I have as a donor car, into my mk. I have taken the gear stick and cables out which are routed along the exhaust tunnel in the ibiza.
How have people then gone to route it in the mk1. I think i'v read somewhere that you cut a hole in the bulk head a feed the cables through, if so where abouts is best?
Also is it as simply as just bolting the stick where you want with the 4 holes or do you need to modify the black box around it or get rid of it completely.
Many thanks
