anyone help me with my front seat situation?
(In Topic #159431)
plastic clips are baffuling me
Anyone know?
If someone has any pics or summat that be such a help
Thanks dan
http://www.golfmk1.co.uk/images/SeatGuideS1.JPG
if so it fits over/between the gap of the front fixing point where the slider handle goes through and locks the seat in place, i'm pretty sure it only fits one way as there should be a little tab on the side which holds it in place, sorry have no pics so i hope that makes sense.
are your two rear clips old and worn? new ones might make the seats rock less and be a tighter fit when inside the rails, i know i need new clips as my seats rock like a ***** and i think one on the passenger seat is missing too
hope that helps
'83 formel e
you got a pic of it?
'83 formel e
COTM Team
mk1 golf seat runner - Google Search
the clip things
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=bodywork-fittings-and_2%2Fseat-runner-help
The mystery bit you have is for cabbys, and you need the part in ned-h's pic and you'll be sorted
'83 formel e
Last edit: by ned_h
'83 formel e
'83 formel e
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/Cv4AAOxyY9VRQctF/$T2eC16N,!zUE9s389y3-BRQctE5W(!~~60_35.JPG?set_id=8800005007
and it doesn't fit, then i suggest getting some like the ones i have and trying those instead, may do the job
but this one above just sits over the metal part in pretty much the same way with the curved part going down inside above the locking pin and the other part sitting on top for the centre seat rail to slide on top
'83 formel e
if the ones you have aren't working then maybe try getting the s1 ones and see if they work
'83 formel e
http://www.ebay.co.uk/itm/GOLF-MK1-POLO-MK1-EARLY-FRONT-SEAT-RUNNER-CLIPS-321881203-X2-GENUINE-NEW-/350673095707?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item51a5becc1b
If you look in your first pic you can see how it sits 'upside down' with the base of the triangle uppermost.
I got a bit confused on the early/late description meaning S1/S2 tintop but I guess it means pre-1983 as early rather than later cabby up to 1994.
