From 1.6 to 2.0 8v what I need
I'm so fu**ing happy.
What cable is? The green and? I can't rembember, a friend says me what is but i forgot LOL.
mk1 clocks
1. open mk3 coil, run wire from -ve terminal inside to fusebox pin g1/12 (cut the old wire)
2. bin the mk3 coil, chop the plug off. crimp a spade to the black wire, bin the brown wire. pull the green/red wire back towards the ecu.
next find the TCI plug on your old wiring loom, its the 7 pin thing in the scuttle. fit it to the mk3 engine bay the same way it was before, but splice the green/red mk3 wire to the tci unit pin 7. bin the other 2 wires from the tci plug that used to go to the distributor. run a wire from the coil -ve to g1/12
fit mk1 tci and late mk1 or mk2 coil (check the plug lead connection compared to the mk3 coil) job done
I prefer option 2, as the mk3 coils are unreliable. but you could leave it for now and convert it later
First or second gear, undertorque (sorry Google translate suggest me this i hope it's right) and try to start or get more accelerator, the car litteraly jump and tug!! It's like a crazy horse!!
How I check to understand what the hell is wrong?
Sometimes i can listen a noise like 'tictictictic' from one or more cables! Maybe that's the problem!
Other question:
In this photo i circle a pipe that i close, BUT i look at etka and it goes to a CHARCOAL CONTAINER.
That's absoluly essential?
Thank u!!
