G60 Conversion
(In Topic #155290)
Now I have picked up various bit's and pieces off the forum about what is required and what's not but I might need a bit of advice as my car has a non standard engine in already!
I have everything off an 83 gti to fill in any gaps due to my current car being a small block chassis.
Will have some pics tomorrow of what I've taken on!
Anyway, the engine is from an Audi A3 and it came with a cable gearbox and shifter (will find exact model number).
Rich
Last edit: by Rich.
First bit of bad news though. The engine arrived damaged I don't know how the couriers could have done this but the rocker cover is squashed at the front, ecu was on the engine in the same place and was squashed, instrument panel was on top and shattered and finally the loom was damaged.
The seller is apparently going to send me replacement parts next week.
Last edit: by Rich.
Last edit: by Rich.
I want to give my new rocker cover a thorough clean, can anyone recommend a cleaner I can use and soak the cover in.
G60 Fly Wheel & VR6 Clutch £243.50 http://www.ebay.co.uk/itm/VW-GOLF-MKIV-1-8-TURBO-G60-FLYWHEEL-SACHS-VR6-CLUTCH-/360511470691?pt=LH_DefaultDomain_3&hash=item53f0287c63
Turbo K03s £300.00 (guestimate for second hand)
Intercooler £125.00 http://www.toysauto.co.uk/product_info.php?pName=front-mount-intercooler-mk1-golf-gti-20v-turbo-cupra-1
Engine / gearbox mounts £195.00 http://www.justcaddys.com/20v-18-turbo-mk1-mounting-kit.html
Loom conversion £100.00 (guestimate)
Ecu unlock £75.00 (guestimate)
Exhaust manifold £212.60 http://www.toysauto.co.uk/product_info.php?pName=vw-golf-gti-20v-audi-a3-tt-leon-turbo-exhaust-manifold&cName=manifolds
Turbo Downpipe £176.00 http://www.qpeng.com/component/option,com_virtuemart/page,shop.product_details/flypage,shop.flypage/product_id,19/Itemid,75/
Forge Turbo inlet pipe £151.41 http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=1703&product=FMGOLFIND
Turbo Pipes £100.00 (guestimate)
Cambelt kit and water pump £200.00 (guestimate)
Oil, coolant, filters, plugs etc £100.00 (guestimate)
Air Filter £80.00 (guestimate)
Brakes (G60 calipers, lines, discs, pads) £300.00 (guestimate)
Slimline radiator (not sure if this is required as have top mount rad at present)
Fans (again not sure if necessary)
Fuel components (Not really sure what I need yet as have carb tank )
Further tuning to goal power £400.00 (max possible torque)
100mm Drive shafts and cups £144.99 http://www.ebay.co.uk/itm/MK1-GOLF-100mm-conversion-drive-shafts-1-8t-2-0-16v-vr6-brand-new-/290896445600?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43bac780a0
Total £2903.50
Last edit: by Rich.
Does anybody have any tips for removing the flywheel without the special 3067 that locks it in place?
Last edit: by Rich.
I hope there is a way I can reduce the number of pipes!
I can't believe how many I've removed so far!! lol
smudger1980 said
Yeah you will be able to lose a few during the conversion. Will you be fitting an oil catch tank as well???
Yes will fit a catch tank
What rubber bushes should I order up for these?
Rich
Last edit: by Rich.
matt
pazwaa said
Hi. Very nice looking car, love the yellow paint with the dark wheels. Hopefully you got the bad luck that comes with all mk1 golf projects out of the way at the start with the broken engine, fingers crossed good luck with the project.
matt
____________________________________________________________
__
WOW Gold|Wow Gold Kaufen|Diablo 3 Gold|Guild Wars 2 Gold
