How do you tell the differnece from a 90 PS engine to a 112 PS engine ?
![CraigSherriff in the usergroup ‘Paid Member’ CraigSherriff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![CraigSherriff in the usergroup ‘Old timer’ CraigSherriff in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Hairyarse said
Oh not good - Have you tried Euro car parts?
I did indeed… simliar kind of problem.
For someone with limited knowledge the multitude of variants for one part is over whelming : (
1990 - Cabriolet GTI 1.8 (DX)
rubjonny said
Thank you…
I wish this was easier. For example, today I went and picked up a rotor arm for my 1991 cabriolet (GTI) They gave me a BERU EVL 085 … but … looking at the website, I should have got a EVL 096 as my engine code is: DX 143 983
More confusion, the part I have today looks just like the one on my car, does that mean my part was wrong from the start??
I got a dizzy cap with part number BERU VK360 which according to that site is the correct one but then i should have a bosh rotor arm
with the cap it'll either fit or it wont I think?
rubjonny said
the 2 rotor arms 085 and 096 are compatible, its just 096 has a rev limiter built in. some mk1 will have the limiter in the pump relay instead. if you have no limiter in either this means you'll just be careful not to over-rev the engine is all, theres no power up at the limiter anyway so there is no reason to rev that hard.
Thank you : )
To replace these parts do you simply unplug the leads and plug them back in the same place on the new cap? Is the rotor arm easy to replace?
I will give it a go and see if the part is wrong, guessing it just won't fire or start if I've got it wrong??
rubjonny said
yup you got it!
Cheers for the help, may nip out now and sort it : )
CraigSherriff said
rubjonny said
yup you got it!
Ok,
Just been out and replaced both parts (That was easy enough)… Think my problem though is still there.
This car is amazing, once it's running! However, it does not like to start very well.
Key in > Engine turns > and turns > and turns > and turns…. You get the picture
rubjonny said
is this only on a cold start, or warm start, or both?
Hey,
Seems to be just on the cold start… I bought a "Coolant Temperature Sensor" and replaced earlier on this evening.
mark1gls said
Try unplugging the electrical connection to the 5th injector and then try to start the car from cold, if it starts better you have leaking injectors, they leak petrol when the engine is off and when you start the the car the 5th injector adds more fuel and the car is flooded hence its hard to start. Try this for a few days to see what happens.
Good to hear from you again mate : ) Coming to my aid again !
Which one is the 5th injector
looks like this. http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-SCIROCCO-AUDI-8V-16V-K-JET-5TH-COLD-START-INJECTOR-/390485892566?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5aeac5ddd6
mark1gls said
If you stand at the front of the engine it's on the left hand side near the suspension strut, its got a braded fuel line and a blue electrical connection pluged into it, press the metal clip in to remove the electrical connection and tie it out of the way of the manifold. The 5th injector only runs for 10 secs or so on start up so it won't affect driving if its unplugged.
Cheers Mark,
Haven't got round to looking as yet as I've had some things to tend to I'm afraid. Hope to have a look on Monday as I'm going away for the weekend.
