From 1.6 to 2.0 8v what I need
![LaJe in the usergroup ‘Local’ LaJe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Now the problem is the lift pump: don't arrive the power. I try to connect direct power from the battery and it's work, but with the wiring nop.
What i check now?
Last edit: by LaJe
Ground problem now i can read the ecu.
I've only one error is the key signal to low.
I try to renew all but my vag can't do the work so i try using vag from dos but it doesn't recognize channel 00. Is it 0 the right channel?
when you say vag-com from dos, are you using a REALLY old version then? try this one:
Ross-Tech: VCDS-Lite Download
what channel are you trying to read? the ecu is 01 and immobiliser is 25. unless you mean measuring blocks? if so you would be 01 engine, then 08 measuring blocks, then go up and down to read each section
Uhm i haven't another reader… Fuuuuu… Is it not the key match?
the key is matched to the immobiliser box not the reader coil,. so as i saay you can steal one from another car and fit it no problem. can be any mk3/vw/seat from around 96-98, surely you must have SOMETHING over there you can rob one from
There are another things that can do this error? I already do the rematch chip - immo - ecu.
worst case get the immobiliser defeated,. you said earlier you knew someone who could do this didnt you?
But she doesn't star yet.. no error.
does the car not even fire up then? if not then its not the immobiliser as that will only cut in a few seconds after the car fires
Nop no fire…
