Windscreen Wiper Motor Replacement
(In Topic #154360)
![robmarley in the usergroup ‘Newbie’ robmarley in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Does anyone have any suggestions of where to look?
Any advice would really appreciated.
Thanks in advance.
R
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/th_fff9e3ea.jpg)
![Brad. in the usergroup ‘Old timer’ Brad. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I'm not doing the work my self, the car is currently in the garage and the electrician phoned to say he can't find parts anywhere.
Is it pretty simple to replace with a MK2 motor? I could suggest he orders one of these?
Thanks for your help
![entersoundman in the usergroup ‘Regular’ entersoundman in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
rubjonny said
mk3 golf are same as mk2 and newer, loads more in scrappies too. as above get plug and length of wire, either splice it to old plug wiring or crimp spades on and push into mk1 plug
I did this to mine in December (S/H Mk3 and crimp on spades) easy to do takes 15mins.
Big improvement! I got mine free but you can get them for £10 quid easy.
'89 Clipper Cabby White Light Mod's
Audi A3 2.0 Tdi Quattro S line Light Mod's
Thanks again,
r
ps. very new to Golf electrics so sorry if questions have obvious answers!
Was it definately a MK3 one as the part numbers for the MK2 and 3 ones are different.
I took It off the car myself
entersoundman said
If anyone is interested the mk3 part number is 1J0955119
Does this require any different mods to the MK2 one to make it fit the MK1?
incidentally, the mk3 motor is also the same as early mk4 golf! but watch out as the mk4s have a missing wire to the motor, so make sure the motor you pinch has all the terminals in the socket. its only listed for 98-01 golf/variant, but listed for 99-10 beetle. also for 91-04 transporter, 89-96 corrado, 92-98 golf/variant, 88-97 passat (variant just means vento, bora, estate etc)
there are lots of numbers for both! MK2:
192 955 113 a ← mk2 part
251 955 119 ← ??
corrado/mk3/early mk4:
702 955 113 a ← ??
535 955 119 a ← corrado part
1h1 955 119 a ← mk3 lhd part
1h2 955 113 a ← mk3 rhd part
1h2 955 113 b ← mk3 rhd part
1h0 955 119 ← mk3 part
1j0 955 119 ← MK4 part
1c0 955 119 ← new beetle part
Last edit: by rubjonny
No mods at all, I took it off with the wiring plug from the mk3 and put spade connectors on, bolted to the linkage and plugged them into the plug on my mk1, leaving off the mount which is not on the mk3 motor as its on the linkage.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/3Avatar.jpg)
![butleraw in the usergroup ‘Paid Member’ butleraw in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![butleraw in the usergroup ‘Local’ butleraw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
