'83 Gti 16v turbo
Been at it today… Repaired the striped flange I had complete with new bearing
Cut my gear shifter and my old one to weld together so I could use my ally golf ball
Chucked a slim line fan ont top fill rad
NEW WHEELS!!!
Needs to come down a bit but my coils are seized
Nice rims btw
Brad. said
Thanks lad! No chance if her moving in yet… Doesn't know about the series 1 either
and so it begins, hiding cars and parts purchases is a real skill.
Wd40 ain't budging coils either we have stronger penetrant at work and that won't
Got some tidying up bits done yesterday and swapped wiper motor for a mk2 item
Also tidying yet more wiring up so it looks neat in there, will be attempting some lathe work on say to make a spacer for my trigger wheel and hopefully, a strong one at that, get it fired up!
Glad you approve though
Megajolt is mappable ignition, so I can map my advance and control it more than the Kr setup
Simple enough once its read and understood
Brad. said
Cheers fella, its the reason I can help you out with the box and what not same heartaches over here!
Ah i get it, one thing i wud do tho in my opinion is go back.to.the deeper splitter, i never usually like the deeper one but on.urs it just looked sweet as mate
Brad. said
Cheers lads!
What's the stronger stuff you've tried? Is it ACF50? That's supposed to be the danglies
Made a spacer up for my crank wheel, needs spacing out due to the rubber dampener on the abf pulley can cause false signals
So, exhaust on tomorrow, finish coolant system (pipe rad up) and then, fingers crossed, start up day! Fingers crossed
golf_coupe said
Looks good on the cookie cutters
Cheers fella
smudger1980 said
Good luck dude
Confident in my wiring
