Jimbo's Mk1 Golf 1.8t
Bought some things off the internet;
new window wipers;
and a front engine mount;
replaced the old N/S tie rod bellow;
also started to remove the O/S tie rod, but its not that straight forward, the tie rod end wouldn't come loose, so ended up grinding it off then heating it up and smashing it out¬;
roll on tomorrow…
i could then get minimal movement with some spanners!
and wallah;
old vs new
new track rod/end on;
also put the front brakes and coilovers on, replaced the leaking rear N/S brake hose, and some welding near the rear axle…
how she sits tonight;
just need to bleed the front brakes (already did the rears then the auto bleeding thingy decided to break), and source a mk1 front drivers seat!
also booked MOT for monday
32MPG isn't too bad if you were playing about but then again you didn't sort the car for MPG did you.
cheers for the brake parts too, just need to get round to fitting them now
'83 formel e
