'83 Gti 16v turbo
![penarthur66 in the usergroup ‘Regular’ penarthur66 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Brad. said
Hardest part I ha was the cables, they're mega tight (I have gsf rocco cables)
Had to kinda bodge em last time with threaded sleeves to get them to fit. But with interior out I had good acces with mole grips etc to get them rightmore than happy with my progress on it upto now as I've been in my unit 1 month and also knocked 2 spits up for others aswell as doing my car
Did you leave the engine in when you had it on the spit?
I wouldn't trust the fluids staying seperate in the engine whilst spinning it.
Can make
You a spit if you like though
Brad. said
No mate. Not only the added weight whilst Turing it (heavier than you expect)
Can make
You a spit if you like though![]()
I didn't think you would have! I am steeling myself (geddit) ready for making my own, but have to practice a bit of welding first. I'm thinking of using some 4x4 timber posts to make the inverted "T" and only use steel for the crossbar and arms.
I still have to remove the engine and running gear - interior, doors and windows have already gone…
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/95image.jpg)
![Dubbuds in the usergroup ‘Old timer’ Dubbuds in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Dubbuds said
Lot of work going on mate. Great build happening
Cheers fella
![](https://vwgolfmk1.org.uk/uploads/pbextract/1277434/E09FAD5A-5589-43F2-835A-EDE0450D0EF3-1471-0000023B197F88D3.jpg)
And also
![](https://vwgolfmk1.org.uk/uploads/pbextract/1277434/AD35D8FD-5894-481A-BE56-AD57960987F0-1471-0000023B2013A260.jpg)
Deadline met and also been sorting alot of unwanted wiring and bodges that I wasn't happy with (previous owner)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1278346/FA267D9B-8135-4250-8CE3-FE8B614AD8E2-3963-000004EF019816DA.jpg)
Megajolt wiring, runs an edis module from an old ford and basically gets signals from a throttle position and a crank sensor. Once you get to terms its quite simple to get the wiring sussed
Tuck ready for wrapping
![](https://vwgolfmk1.org.uk/uploads/pbextract/1280441/0F9128A9-B632-41A9-9444-7AF2446A644D-11886-00000F2E9FD605B0.jpg)
And how the bay is at the min
![](https://vwgolfmk1.org.uk/uploads/pbextract/1280441/17472508-8D6E-42B4-9A85-4916828AC19F-11886-00000F2E981D1480.jpg)
Waiting for a spacer for the crank pulley so my trigger wheel can sit nicely then I can run her up and tweak bits, also got some wheels coming this week I got for a bargain!
![Pipsical in the usergroup ‘Local’ Pipsical in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i31.photobucket.com/albums/c363/Philip_123/b8074bc8-ce23-4305-b98c-9a92146e182d_zpsddbd7b63.jpg)
Safe journey for those going to Elsecar.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1281676/564E62C8-1F7F-40C6-8A7E-C617DCD29FAA-3429-000003BE7898C6C8.jpg)
Also my rear engine polybush decided to be gay and strip so I've 'modified' that and will be all bolted up on Sunday
Which rims are they mate??
Gunna have to do some
Pluming to get the fitment how I want them, although my coilovers are seized
Plusgas helps with the seizing issue. Spray a few times a day a few days before you intend to tackle the job
![](https://vwgolfmk1.org.uk/uploads/pbextract/1281733/C7E712F6-7615-4BC4-B765-18DB2FFAC840-3784-000003E743CAA1FF.jpg)
Nothing!
P.S You need to hoover
