DX to ABF conversion wiring
2) cold throttle enrichment no need for it on abf
3) yup no need for this
4) indeed
yes the abf oil sender is in the filter housing, use the kr one just in case the abf one is different rating. its different part number so i assume it is. and yes, run the live direct to spade in back of fusebox
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2013-02-18%2016.jpg)
![mk1mick in the usergroup ‘Regular’ mk1mick in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
one more thing! the green/black and red/white (oil sensor & outside temp sensor) which go to two pin black plug behind board- I cant find anything to connect them to- I guess they werent connected when running KR- where are they meant to go to?
cheers!
the oil and outside temp wires run off to the dash, if you dont have mfa then no wires
It is a gti model with mfa, so I should have a black two pin connector somewhere for the outside temp and oil temp plug to go to right? If so, where does it connect to on dash? I havent pulled dash out to look for it but seems I may have to.
Anyway-what I "rang" for: the black wire coming from immobiliser box- I have searched online, inc you diagrams but still cant work out what to do with it. Other posts relate to CE2. From wiring diag it seems to be a permanent live feed but that doesn't see right? I may also be confused about the jumper box wires; please clarify what should be thee- I have two grey/white wires and a yellow.
I take it I just blank off the two hose connections on the inlet near the throttle (carbon can and airbox connections)?
immobiliser should have some brown wires which are earth, and a black wire which is ign live. then grey to egu, and grey to diagnostics block. then diagnostics port plugs into the block as well. port will need a live and earth.
cap off the throttle body connections aye
immobiliser would allow car to fire up for a few seconds then kill spark. maybe crank sensor? best get diagnostics plugged in see whats up.
up to you with reverse wiring really
![crezz in the usergroup ‘Local’ crezz in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
�UR-)<strip the abf loom down, remove the lighting, battery +ve and -ve wires, fan controller, fan etc. anythign that isnt connected to the ecu. you'll be left with an earth wire from the ecu, splice this into the TCI loom earth to battery.
im trying to get my head around doing all of this but dont have a ce1 fusebox infront of me, (waiting on delivery)
when you say strip it back, are you cutting them off so thinning the loom down, example, lighting… yellow plugs a1 a2 ect become redundant (wires can be snipped and pulled through other end? i had started un tapping it all but all the combined earths (brown?) make it impossiable to remove without cutting.
Chop all the thin brown earths off the chunky brown -ve cable, this will make your life much easier removing all the unused gubbins! both the battery cables to the fusebox want removing as you'll be using the mk1 battery cabling.
as you say there are loads of wires running back to it. there are only 2 engine earths to it one from the ecu and the other to the coil. since the coil is going to be binned in favour of mk2 coil plus mk1/2 electronic ignition unit and wiring that just leaves the ecu earth, which you tap into the TCI unit earth back to the battery
2. horn (bin)
3. headlight (bin)
4. lambda (keep)
5. brake fluid warning i think, wire colours? (bin if so)
you sir are a diamond!
i havent done an awful lot at the fusebox end, as im waiting on a ce1 fusebox to turn up and engine loom..
hopefully vrupper is going to pop around tonight to see if he can help with whats left. well update you with where im at later on.
thanks again for your time and patience
i have at fusebox end
pin 6, yellow blue, g1 3
pin 7, red starter, f 1
pin 8, green red, back to dizzy plug
pin 9, black white (86a)?
pin 23, black yellow 87 ecu?
pin 35, blue white, speed signal? bin?
pin 38, blue black ? ignition live?
pin 51, purple white? mpg?
immob plug, earth ring, green single pin plug
hefty black lead with red plug, with red lead and red plug, and bare red cable
brown white g1 5 cylinder head earth?
red whitr g1 8 oxy sensor?
brown black f 8 crank vent?
blue black f 7 back up?
green black g2 1 oil temp?
blue white g1 11 speed sensor? again?
yellow red g2 3 coolant temp?
blue f 3 battery light?
blue black g2 11 low oil sensor?
black red f 6 back up?
yellow g2 10 high oil pressure?
black g1 4 earth?
blue black g2 4?
green black pin 67?
