Phils Mk1 Golf GTD Build
Slow and steady wins the race
But the reverse to the end of my drive was great.
Are those the OSVW top mounts? I need to replace mine again so I was thinking of springing for those.
Pipsical said
ColTech Classics
I might end up with a set of those at the rate I am going with mine. The weight of the 20v engine at the front is causing issues with my wheels not fitting.
Going to raise the car up today so i can use it daily to get the miles up :-D
Again shouldnt have as i cought the exhaust on a cats eye and it fell down and scraped.
Also the car is sat on the drive shaft, which has caused a massive/deep scoring.
Ah well..
Need to sort the oil leak though :-(
Just thinking what exhaust to get, not sure on the tail pipe design..
Raised the car 20mm which gave me 10mm clearance on the driveshaft.
Also fixed the exhaust hanging down by making a bracket and fixing it to the fuel tank strap bolt, so thats well away from the floor now. Going to drive to work tomorrow and friday to get a few more miles on the engine.
I still need to sort out the water pump for the turbo as i dont think its working. (The pump works but unsure if the ignition live i used is duff/bad earth.)
Weekend should be fun :-)
Put my water pump on an ignition live and wired a bypass switch onto the main cooling fan to turn on when i want. (mainly for ques at shows).
Going to look at getting some sort of head unit at the weekend.
