mk1 20vt wiring HELP ME!
(In Topic #152279)
emoticons__BangHead:
important wires are:
1 - main ecu live
2 - earth
3 - permanent live
4 - fuel pump earth trigger
6 - rev counter (need adaptor)
19 - diagnostics
67 - sensor earth
I killed my first ECU, similar problems to you.
got a second one from ebay, the car turned over and sparked etc, then got it deimmobilised and it works ok
all the right relays in place and known to be working?
how have you wired up the relay? if you're using the factory relay slot on the fusebox you can fit a 17/18 relay to make the pump live with ignition. its not safe in the long run (if you have a crash) but it will help you diagnose the problem
Old dubs never die, they just get lower
even if it was immobilised it would still trigger the fuel pump even if it wont fire car. trouble is unless you tried the ecu before you sent it off no way to know if he killed it or if it was already dead. i have seen a few people with blown ecus they seem quite sensitive!
Can you do de-immobilising Jonny as part of your service?
rubjonny said
yeah thats what they do, well mk3 golf engines do anyway and im pretty sure mk4 are the same
yep they do,
