Phils Mk1 Golf GTD Build
![Pipsical in the usergroup ‘Local’ Pipsical in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Slow and steady wins the race
![](https://vwgolfmk1.org.uk/uploads/pbextract/1267736/226804_10152536783755467_1687817764_n_zps583c24eb.jpg)
![](https://i31.photobucket.com/albums/c363/Philip_123/b8074bc8-ce23-4305-b98c-9a92146e182d_zpsddbd7b63.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/224image.jpg)
![Mike 16vG60 in the usergroup ‘Paid Member’ Mike 16vG60 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Mike 16vG60 in the usergroup ‘Old timer’ Mike 16vG60 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
But the reverse to the end of my drive was great.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/1301414793353.jpg)
![clump in the usergroup ‘Regular’ clump in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
Are those the OSVW top mounts? I need to replace mine again so I was thinking of springing for those.
Pipsical said
ColTech Classics
I might end up with a set of those at the rate I am going with mine. The weight of the 20v engine at the front is causing issues with my wheels not fitting.
Going to raise the car up today so i can use it daily to get the miles up :-D
Again shouldnt have as i cought the exhaust on a cats eye and it fell down and scraped.
Also the car is sat on the drive shaft, which has caused a massive/deep scoring.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1268379/2048BC54-C9DD-4330-8EFC-83FEE185373A-4640-000006971E211C6D_zpscb946dbe.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1268379/06B7662B-0F52-4F20-8C9F-3F36616F5734-4640-00000697184DD4CD_zpsc067bbc8.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1268379/6B9C6A52-E501-4162-9DD6-1E309EDB302D-4640-00000697229E79EA_zpsa61785be.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1268379/CEAA008C-ECE0-4680-B854-AFEACF896EB1-4640-00000697274E03EF_zps6e112c46.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1268379/1B37120F-4887-4409-A823-6CC989142F6C-4640-000006972C53C577_zps17550eed.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1268379/99715986-BA06-42F1-886E-E2ECE8FB7DA3-4640-00000697320700D3_zps010cdcb3.jpg)
Ah well..
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/half-life.jpg)
![jellybelly in the usergroup ‘Paid Member’ jellybelly in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jellybelly in the usergroup ‘Regional Hosts’ jellybelly in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![jellybelly in the usergroup ‘Old timer’ jellybelly in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Need to sort the oil leak though :-(
Just thinking what exhaust to get, not sure on the tail pipe design..
Raised the car 20mm which gave me 10mm clearance on the driveshaft.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1269713/CD1EB20A-2722-4BD1-AAB9-A3D9C9503863-6928-00000991D9204407_zps559123bd.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1269713/D9F8D5DA-7528-4213-8B93-98509D7FCBB7-6928-00000991D3EE2054_zpsa7e290c9.jpg)
Also fixed the exhaust hanging down by making a bracket and fixing it to the fuel tank strap bolt, so thats well away from the floor now. Going to drive to work tomorrow and friday to get a few more miles on the engine.
I still need to sort out the water pump for the turbo as i dont think its working. (The pump works but unsure if the ignition live i used is duff/bad earth.)
Weekend should be fun :-)
Put my water pump on an ignition live and wired a bypass switch onto the main cooling fan to turn on when i want. (mainly for ques at shows).
Going to look at getting some sort of head unit at the weekend.
