JB's 1:18 Scale Garage Showroom Diorama
(In Topic #151591)
Heavy Geek Content!!!!!OUT OF HAND...!!!!!
around November time, i came to the realisation my model addiction was getting out of hand, so i thought i would go outside to work on the real thing…….TO COLD!!!!
so came back inside and thought i would build a MINI garage to store my model MK1's in
well it's gotten a little out of hand
to give you an idea i will show to a picture of how it stands tonight
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120818_zps60a41979.jpg)
so!!!!!!!!!! back to the begnining of the build
B&Q (other DIY stores are availble) MDF was purchase then the marking out commenced
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120442.jpg)
before to long we had walls, door holes and windows
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120443.jpg)
floor plan was finished in a gloss white vinyl
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120444.jpg)
next up the outer wall get painted a morter colour ( all will become clear)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120447.jpg)
then for dolls house you can get a stencil and a brick paste that you apply over the paint to give you a really realisic brick finish
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120450.jpg)
interior walls were spray painted gloss white over the brick finish
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120449.jpg)
then the exterior looks like this, this is why you pre paint grey to make it look like the mortor
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120454.jpg)
so are you keeping up so far…….!!!!! at this point everything had started the spirel out of control
you can by scale snap of tools and car lifts, ebay got a hammering this week
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120455.jpg)
outside tarmac finished was applyed, consisting of sand, pva and blackboard paint
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120459.jpg)
things are coming together
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120461.jpg)
thought i would screw it all together, put a nice flash red band around the walls, and i had to see what it looked like with the car in there
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120467.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120468.jpg)
next up the roller shutter door need to be made, so balsa wood, fabic, paint and a little time later
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120472.jpg)
these are full operational doors
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120473.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120474.jpg)
then the windows and doors were lined and architrave was fitted, to take the acrylic windows
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120475.jpg)
then with every good warehouse need rafters
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120481.jpg)
also see and the tools and ramps……. love it
favorite picture so far
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120484.jpg)
so then decided it needed to be illuminated, ribbon LED were purchase
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120534.jpg)
then it was installed around the inside of the building, in a channel i porduced at work, also notice the little HSE signs
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120540.jpg)
then a pully was made to finish the roller shutters
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120803.jpg)
fitted with a peice of small chain the finish the job off
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120804.jpg)
then more lights were made to look like flory tubes
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120806.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120807.jpg)
then i decided it need outside lights, so i made these little ones at work
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120810_zps0d86cc67.jpg)
fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120813_zpsd23df72c.jpg)
what it looks like lite up
![](https://i436.photobucket.com/albums/qq81/mwhitehead44908/Garage%20Diorama/P1120816_zps1110d632.jpg)
so for all these lights i needed a scale switch board
![](https://vwgolfmk1.org.uk/uploads/pbextract/1263199/P1120809_zpsb32881fa.jpg)
not wired this in yet but that brings you up to today
that it told you to sit comfy
Web Team
![Hazza in the usergroup ‘Local’ Hazza in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk1 golf GTI 1.8 - bargain buy
Suzuki Samurai - 4WD 1.7 TD Conversion - Off roader
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/aaaa.jpg)
![arf333 in the usergroup ‘Regional Hosts’ arf333 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![arf333 in the usergroup ‘Old timer’ arf333 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
You are in no doubt extremely gifted and possibly completely bonkers.
(the detail you go to
![:nod:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/nod.gif)
So my challenge to you is this.
When finished you will have a lot of money parked in that workshop, so you must install 'Video Surveillance'.
Working of course!
Fantastic job JB, keep the pics coming. You've still got a few weeks before you get back outside to the real thing!
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fimg1.jurko.net%2Fuploaded_70725001942aa6734990be.gif)
![DubPartz in the usergroup ‘Local hero’ DubPartz in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
DubPartz
It's big enough for me to live in lol.
How much rent you want. lol.
Seriously good. Forget the cctv I want to see a full rolling road set up in there lol.
Don't give JB anymore encouragement or ideas until he's finished the working toilets and showers!
Good stuff though, rolling road.. I got a couple of electric motors here, mind you they would catapult any cars off the rollers lol…
What about figures mechanics, secretaries and sales men lol…Plus you need a ramp, working of course..
Shall I stop now..lol
![Avatar](https://i37.photobucket.com/albums/e93/ans4r/avatar-1_zps02a271d4.jpg)
Social Media Manager
![ans4r in the usergroup ‘Moderators’ ans4r in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![ans4r in the usergroup ‘Paid Member’ ans4r in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![ans4r in the usergroup ‘Local hero’ ans4r in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://i64.photobucket.com/albums/h175/76ball/The%20Roc/MADINMAN.jpg)
![VWinston in the usergroup ‘Local’ VWinston in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://farm8.staticflickr.com/7397/9354596510_4bf6aea073_o.jpg)
The Mk1 Golfs older and better looking sibling……..
Disgruntled customer?
Swearing mechanics?
Porno mags?
Nice work Jelly!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Ajs%20golf.jpg)
![mk1aj in the usergroup ‘Regular’ mk1aj in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![AntF in the usergroup ‘Old timer’ AntF in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
How much to build me one?
![watson in the usergroup ‘Old timer’ watson in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
