mk1 20vt AGU wiring diagram
(In Topic #150781)
![ezzoG60 in the usergroup ‘Regular’ ezzoG60 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
is there any DIY diagram to make it work?i have the full donor car but i'll decode the ecu so i don't need to use clocks and keys.
what i need to know is,what is the basic diagram to make the engine work.
if it can help the agu is cable operated throttle and i won't use:
PAS
A/C
electronic speedo
thank you very much!
thanks
agu is similar to aum/auq, just be aware on the really early ones the pinouts on the coloured plugs differ slightly. see my sig i have agu early and late diagrams
