Calling all Cabby owners with 8x15" alloys
(In Topic #150520)
![P0jy in the usergroup ‘Regional Hosts’ P0jy in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![P0jy in the usergroup ‘Old timer’ P0jy in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Currently Mk1less!
Currently Mk1less!
![funk-star in the usergroup ‘Local hero’ funk-star in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![dik-van-dub in the usergroup ‘Local’ dik-van-dub in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Old dubs never die, they just get lower
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
![MK1Morley in the usergroup ‘Local’ MK1Morley in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
New to Golfs - All Help Appreciated!
MK1Morley said
Ive just put some 15x7 on mine and even that was running it close so personally to put 8Js on i think it would be more hassle then its worth!
Really, I'm getting mixed views on this.
Some of the guys over on edition38 are saying it should be fine.
I'm not so sure now…
Currently Mk1less!
Currently Mk1less!
The wheels I want to fit are Axix OG alloys in the same colour combo as the RAs, they are et25 and 15"x8" however with 195/45/15 tyres…
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
![Andis3 in the usergroup ‘Regular’ Andis3 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
No rubbing issues at all and no arch work required!!
Good luck with whatever you decide to do.
Andis3 said
Thats one of the reasons i split my RM's as they came as 7 1/2" for the front and 8" at the rear.They are now 6 1/2" front and 7 1/2" rear.
Hi Andy
If only your centres were black !
Currently Mk1less!
Currently Mk1less!
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/trees.png)
![Sportline-Toby in the usergroup ‘Local’ Sportline-Toby in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
My OZ Turbos that I built were originally ET33 and I machined another 5mm off the mounting face making them ET 38. Then this obviously changed a great deal by replacing the dishes with 2.5" outers.
Yours should fit as they are but remember, you can machine the face to adjust if they are too close for comfort.
The tyre size you mention is spot on for getting lows
Sportline-Toby said
I have a sportline (can you tell by the name haha) and I currently run 9x15 on the back and 8x15 on teh front. I dont get rubbing issues and im low. It all depends on your ET. Ideally you need ET 30 or maybe a tad more.
they are ET 25, i'm not sure if that's higher or lower…
Currently Mk1less!
Currently Mk1less!
