MK1 Golf GTI 2.0 TFSI Edition 30 p12 (was 2008cc R1 bike carbs)
![Lhasa2008 in the usergroup ‘Paid Member’ Lhasa2008 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Lhasa2008 in the usergroup ‘Old timer’ Lhasa2008 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
1983 Lhasa Green MK1 Golf GTI
fozzie said
Looks good mate those repair panel prices were cheap back then!!
It's nice to know vw classics are reproducing parts again, but at a price.
A pair of genuine front wings, front and back panels are now £££££!
Lhasa2008
![](https://lh3.googleusercontent.com/-mWFhJ9eZme0/UgT9M3FU7KI/AAAAAAAAATg/i19uj2_uPdQ/w800-h600-no/fuel2.jpg)
![](https://lh5.googleusercontent.com/-w2ICNzSGGgc/UgT9NXnqqUI/AAAAAAAAATs/U0JbYXNIPcY/w800-h600-no/fuel3.jpg)
A 50p nut here, and a few 97 pence clips there. I managed to spend £28.95 at GPC on just nuts and bolts!
Parts were sources from GPC, main VW dealers and GSF (171 201 220D fuel pipe, what a life saver - it was obsolete everywhere else!)
Oh, and another £142.75 from GPC for genuine brackets and hoses. £ouch!
Last edit: by Lhasa2008
The main VW dealers had two or three genuine fuel tanks left in stock, but were close to £300 with VAT, so I managed to find a equivalent replacement part from Hadrian car panels for £69.29+VAT.
![](https://lh4.googleusercontent.com/-3tBGALIjuZg/UgT9OOVuW_I/AAAAAAAAATw/T4M2kKyOcqE/w800-h600-no/fuel4.jpg)
Fuel pump, pipes and brackets assembled ready to go back on the car.
![](https://lh6.googleusercontent.com/-Q8uKrtoyJ6U/UgT9OFVIXFI/AAAAAAAAAT8/UeOrowq4DbY/w800-h600-no/fuel5.jpg)
New fuel tank now in place, and new metal fuel lines sourced from GPC. Didn't realise until seeing them in the flesh, why GPC were unable to post them! (These are the long, shaped fuel lines that run from the engine bay to the fuel tank..). A six hour round trip later, and a few hours underneath the car swearing
![](https://lh4.googleusercontent.com/-r03o2kXiPKs/UgT9OkwKneI/AAAAAAAAAUE/CclyyFSEC_4/w631-h842-no/fuel6.jpg)
Fuel pump and bracket now fitted.
![](https://lh3.googleusercontent.com/--rglhOjfZsA/UgT9PHfVK0I/AAAAAAAAAUM/VaVz_xvhKOU/w800-h600-no/fuel7.jpg)
![](https://lh3.googleusercontent.com/-ukqMtEF0TGA/UgT9PQuwVMI/AAAAAAAAAUQ/AB2qycKxIjE/w800-h600-no/fuel8.jpg)
Autocavan (Remember them?) stainless steel fuel filler neck just visible in pic.
![](https://lh4.googleusercontent.com/-uI3DIVXCWfU/UgT9Pv9kfiI/AAAAAAAAAUc/DUt9aoM-3ek/w800-h600-no/fuel9.jpg)
New metal fuel lines fitted along with new clips.
![](https://lh6.googleusercontent.com/-fMtB2NMdfHc/UgT9M0OBLtI/AAAAAAAAATc/30fy8fhBANk/w800-h600-no/fuel10.jpg)
smudger1980 said
It all mounts up mate doesn't it. I've managed over £150 on sundries so far on my build![]()
It's when you hack off a bolt or bracket to save time, not realising it's either
a) Obsolete
b) 'On back order'
c) £34.95 + VAT
LOL
Lhasa2008
I've got to sort fuel lines and fuel pump in the near future so have got this all to come
smudger1980 said
£300 plus VAT for a tank?What a bunch of muppets.
I've got to sort fuel lines and fuel pump in the near future so have got this all to come![]()
I don't think I managed to get a single nut and bolt off intact when doing mine!
I could do with another fuel pump too, mine's got that high pitch noise coming from it.
Anyone recommend a supplier that sells genuine Bosch ones?
Lhasa2008
![MalC in the usergroup ‘Old timer’ MalC in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Lhasa2008 said
MalC said
Very nice mate lots of good work gone into save this….where abouts in east yorks are you ?
Yeah, it could have easily just been scrapped for a few hundred quid at the time.
I'm not far from Pocklington, what about you?
Lhasa2008
Good job it didnt 8)
Not that far….near Selby
![DubSingh in the usergroup ‘Regular’ DubSingh in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I've got a couple of new boxed Bosch item in the garage somewhere which I won't be using if you want to buy. My old ones on my cars had stopped working because they had stood for too long, but I soaked them in carb cleaner and they started working. So I took out all the old ones I had and got most of them to work.Lhasa2008 said
I don't think I managed to get a single nut and bolt off intact when doing mine!smudger1980 said
Lhasa2008
Lhasa2008
![](https://lh3.googleusercontent.com/-8Hcob7VRyGY/UgT9ScywStI/AAAAAAAAAVQ/vrXgnsRAiFM/w800-h600-no/paint8.jpg)
![](https://lh4.googleusercontent.com/-OzNq9dcb-F8/UgT9Sw3PXtI/AAAAAAAAAVo/aGxVgCjtDUQ/w800-h600-no/paint9.jpg)
The rear brake bias was still OK, so this got reused, but I took the opportunity to replace the servo and vacuum pipes, and made up new brake pipes using cupro-nickle kunifer, which I believe is more corrosion resistant (but harder to bend into shape)
![](https://lh6.googleusercontent.com/-g7U28WwKgt0/UgT9JYcJ7iI/AAAAAAAAASU/06xFc649Nqs/w751-h685-no/brake1.jpg)
![](https://lh6.googleusercontent.com/-pytMAdvbK0Q/UgT9J0PdQ2I/AAAAAAAAASk/pGVHPQfMi50/w800-h600-no/brake2.jpg)
Braided Goodridge Hoses used.
![](https://lh5.googleusercontent.com/-kgN5tz31q8c/UgT9KUKufGI/AAAAAAAAASo/O7iZyRsWbTA/w800-h600-no/brake3.jpg)
Crossed drilled G60 disks machined down to 270mm with an Autocavan carrier adapters, to fit snuggly behind Pirelli P 14" wheels.
![](https://lh5.googleusercontent.com/-jnBHqqaMTE8/UgT9KfjWx8I/AAAAAAAAAS0/qNKAUqyOpTo/w800-h600-no/brake4.jpg)
Incidentially, I have been told that these wheels were originally from one of the very first F plated UK VW demo Corrado's.
![](https://lh3.googleusercontent.com/-HfGNSwn8EpE/UgT9emqfReI/AAAAAAAAAZg/y5fVPGLqxXI/w800-h600-no/wheels1.jpg)
![](https://lh4.googleusercontent.com/--SRjjvhdgqo/UgT9ew2DZBI/AAAAAAAAAZs/BPF-66PYOvY/w800-h600-no/wheels2.jpg)
Which means I could now fit these:
![](https://lh6.googleusercontent.com/-KhQW117eokc/UgT9K3bpBUI/AAAAAAAAAS4/iLyhXtkn3pM/w800-h600-no/brake5.jpg)
280mm G60 disks and Wilwood 4 pots nicely tucked away.
![](https://lh3.googleusercontent.com/-cArUPfyznx0/UgT9fY9aGpI/AAAAAAAAAZw/mDfm2YGLppg/w800-h600-no/wheels3.jpg)
(Unfortunately not quite enough clearance to be able to use stick-on wheels weights on the inside of the wheel though)
So a spare MK2 Golf GTI ACD (close ratio) gearbox was fitted by swapping over the MK2 100mm cv cups to the MK1 90mm cups.
I also took the opportunity to fit a lightened flywheel at the same time.
![](https://lh3.googleusercontent.com/-MX868_j8plc/UgT9LBiRkKI/AAAAAAAAATM/XlYO0iE9IDw/w800-h600-no/flywheel.jpg)
Brad. said
Inspirational for me this fella![]()
Thanks.
It was all other existing inspirational MK1's on here that made me want to do mine.
![](https://lh3.googleusercontent.com/-Nui3AHQNTDg/UgT9UGuRY1I/AAAAAAAAAWA/-rL-NCXUE4c/w640-h480-no/rearlights.jpg)
![](https://lh4.googleusercontent.com/-CaYv0Ag5ce0/UgT9T8SdAGI/AAAAAAAAAWI/YDZ8kYE3VY0/w400-h671-no/rearlights2.jpg)
So should now be able to add some info on the engine now
