1.3 standard airbox weber carb
(In Topic #148868)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMAG0048-1.jpg)
![r_chez_08 in the usergroup ‘Old timer’ r_chez_08 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I would like to get the standard airbox on my golf because of potential carb icing. Anyone got a pic of what it looks like, and does it mount straight up to a weber on a 1.3?
Rob
![](https://i695.photobucket.com/albums/vv312/r_chez_08/my%20mk1/IMAG0048-2.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2012-11-24%2015.jpg)
![Gordonthegolfer in the usergroup ‘Moderators’ Gordonthegolfer in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Gordonthegolfer in the usergroup ‘Regional Hosts’ Gordonthegolfer in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Gordonthegolfer in the usergroup ‘Old timer’ Gordonthegolfer in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1244268/_MG_4484.jpg)
Usually Plastic with two fixing holes at the front. The later Polo ones look similar and are usually metal, but im unsure of the fitment as they usually fit onto SPi units
Ive got the Weber 34-ICH carb on mine and the standard air box fits straight on top. Be carefull of the Choke assembly on the back though, it tends to foul the bottom of the air box and play the choke mechanism up. Ive overcome this by bending down the choke cable bracket and shaving some of the plastic off the bottom of the filter casing.
Works a treat!!
PS- Sam hope you didnt mind me "Borrowing" your photo for this exercise
You need the warm air hose from a tin plate bolted to the exhaust fanimold (missing in pic above) to the lower connector of the air filter inlet pipe thingy.
X will be along shortly to show you how he did his.
![Avatar](https://i222.photobucket.com/albums/dd103/iPod_Fixer/000177.png)
![X in the usergroup ‘Local hero’ X in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
This is what they look like:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1244989/b606de9d.jpg)
I've got a 4-2-1 manifold, so my bolts are custom made - but you will see on your manifold there are 3 bolts in a v shape that attach the heat shield.
If you can't find one you can always make one - when I got mine there was a bit of steel plate with a hole cut in it - proper DIY job! But it worked.
I suppose you could try and fix the warm air feed pipe to the manifold, but I don't know how you'd be able to do that.
Ps, chances are those nuts will be siezed on the manifold, get some wd40 or a bloody big heat gun to loosen them off.
1983 Golf 1.3 Driver:
![](https://i222.photobucket.com/albums/dd103/iPod_Fixer/182000_zpsdfa6a837.png)
The oil return breather pipe gets in the way:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1244991/DSCF1902.jpg)
So I sliced it off, sealed it up, and bodged a new joint in:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1244991/DSCF1911.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1244991/DSCF1916.jpg)
And there's a vacuum pipe that attaches from the diaphragm on the distributor, to this:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1244991/DSCF1908.jpg)
The orange bit, the hole next to it is the hole I drilled to fit the oil breather pipe.
Hope this helps
Could someone please tell me the i/d of the pipe that connects the air filter and the manifold shield (the silver one in the above pics)
Thanks!
Rob
![ned_h in the usergroup ‘Old timer’ ned_h in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
'83 formel e
'83 formel e
Oh and sorry for the double posts, I am on my phone and it does wierd things…
Just found a hose on ebay. They do a 450mm length. Will this be long enough?!
Sorry just want to have all the kit together so I can get it all together and put it on in the holidays.
Rob
Better fit, or i'll be on yer back!!
Rob
r_chez_08 said
Cheers, Going to order it up now.
Rob
LOL, i only commited to the length of the pipe, if the diameters wrong ure on ure own :wink:
Chris
If it's the same as mine it goes brittle fairly quickly as well - I'm on my second, and this one has just split. Standard the car comes with something similar, but more robust, a sort of fibre material. Impossible to get hold of (I've tried). Couple of jubilee clips and Bob's yer uncle!
I do not plan on running the stock airbox most of the time, just in the winter, so it doesn't have to look perfect.
![](https://i695.photobucket.com/albums/vv312/r_chez_08/my%20mk1/IMAG0277.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1247771/IMAG0278.jpg)
Would it be okay just to plug up the breather joint in the box and put a little filter on the end of the breather pipe? Mine seems to fowl the throttle linkage if the hose is plugged in, makes it jam. Not good!
Oh and where exactly does the pipe coming from the orange piece go to, and where does the pipe from the hot air feed butterfly go to?
Many thanks and happy Christmas,
Rob
You don't wanna be plugging up the breather pipe in any circumstance. The crankcase needs somewhere to vent at all times. You may need to cut the spigot off where the breather attaches to, then fill the hole. Then re-make another hole and retrofit a pipe fitting to attach the breather too, mines got a little 90 Degree elbow fitted to it.
Chris
