1.8T AEB pipe above oil cooler
(In Topic #145669)
![WittyDubSteppah in the usergroup ‘Regular’ WittyDubSteppah in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
on the AEB block just above the oil cooler there is a breather pipe of some sort that comes out of the block does anybody know what its for
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
id love a quick reply as its fairly urgent need to get it started this weekend and this is one of the few things stopping me.
cheers guys
![Avatar](https://i875.photobucket.com/albums/ab313/peterg60/mk1_zpsbfbbd7be.jpg)
![peterg60 in the usergroup ‘Old timer’ peterg60 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
if you on about this pipe ontop of oil filter
![](https://img687.imageshack.us/img687/4738/123456small.jpg)
that goes to the turbo tip. depends if you using oem tip it goes into a hockey looking thing lol. if you want to delete the pvc and intall oil catch tank follow this
uk-mkvs.net - uk mkvs Resources and Information.
edit. isnt aeb block a passat block?
is this it
![](https://img35.imageshack.us/img35/3513/aebblocjksmall2.jpg)
The pipe comes out of that part in the second pic. It looks like its a
breather pipe for the block.Will I need to install a catch tank like in that link, never heard of that being done in a mk1
Yep the block is from a passat but was converted to run in a mk1 caddy, me being an idiot forgot to photo that part when he took it out.ill post a pic anyways once in registered on imageshack
Nice one
http://imageshack.us/p/uploader/
install and drag pitures across
here is your block see how different the oil housing is
![](https://img9.imageshack.us/img9/1306/1smallyr.jpg)
i would change the oil filter housing
you also might have a external water pump
i was going to use a apu block from a passat after my engine was found to be no good . alot of stuff has to be changed over . i found it easy getting a 06a block
http://img29.imageshack.us/img29/1306/1smallyr.jpg
whats it for?
edit: i know its a crank breather pipe but where would i route it to in a mk1 cabby.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/300520111797-Copy.jpg)
![ShaunyC in the usergroup ‘Local’ ShaunyC in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Also some of the diagrams and other guides i've been through theres a pipe coming from the cam cover… my cam cover dosent have an outlet?? where would i get that from?
Edit : The most common way seems to be.. Crank breather T'd with rocker cover - catch can - TIP/Vented… but is that the best way?? + as, i say i don't have a rocker cover outlet, would it just come straight from the Block breather??
\/\/ The beast to be…!!!
(loads of pics) \/\/
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=95838&highlight=
SSC ELECTRICAL
SSC ELECTRICAL
Im in the same boat as you I have only a crank breather and no head/cam cover outlet. Same engine also.
I asked a mate who races skylines and he said catch tanks are required for med-high boost applications. If your running it stock then.you can just leave a small drain pipe from the crank breather to atmosphere. You'll apparently get maybe 1 or 2 drops of oil on your drive per day depending on how you use it. Also dependant on ecu.
do you have the pcv system in place?
kass
Haha yea so it seems.. up stream with out a paddle! lol
How you getting along with your AEB conversion?? you say the engine was all ready to go?
I have most/all the VAC piping, its just not on the engine, and i would rather get rid of it to be fair
So in theory you could just stick a vented botle on the end of that crank breather and that would be enough??
Or even vent to the TIP? would that need a one way valve on or anything?
I think i'll be going Meggasquirt engine managment? cross that bridge when i get to it! lol
SSC ELECTRICAL
SSC ELECTRICAL
Here's what I'm thinkin for mine and
seeing as you're going for track use, then id put a pipe to a catch tank with vent to atm, possibly with mini filter and that's it.
Don't route it to your TIP as its horrible yellowsludgy crap that comes through there, its oil vapour and water vapour. Makes me ill.
I bought my engine as a complete conversion with emerald and it had no vac piping. Just brake servo and map sensor stuff, from the inlet manifold.
I say complete conversion when I really mean not a complete conversion at all, plus I decided to respray the bay. Nearly there however just fuel pumps and brakes to go plus a quick service. Hoping its done before I get snow….ye right!
