5 speed in a mk1
5 speed in a mk1
i was woundering if anyone  knows if is ts possible to ge a  5 speed transmission in my mk1 golf i feel its  little  high on rpms doing 50-60 mph
1980  golf 1  gls  1.6  4 door
Big block or small?  big block is easy enough.
its a 1588 so  big block i guess
whats the  judgement?  is there an easy way of installing a 5 speed and what do i have to do? and what  car can i get a  trans from?
Well its a simple bolt in job but i did it over 20 years ago so memory is faint, think i used 1600 gti box and linkage, but can offer no more advice.
yes mk1-3 1.5-2.0 all use 020 gearbox that will fit, but you need mk1 5 speed linkage parts and upper gearbox bracket. you have 90mm flanges on your box so bear that in mind, a lot of the 1.8-2.0 boxes have 100mm flanges which means either get later cab/rocco 100mm shafts or fit later 90mm flanges to your box
thank you  very much
now i just  gotta  start  searchin i guess     this is gonna be "fun"
