Rear Brake Disc Help
(In Topic #147744)
![Highwaystar in the usergroup ‘Local’ Highwaystar in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Second problem is I replaced the broken handbrake lever and now it seems if the cables are 1 inch short . Only thing I can think of is the cables are original and not for discs. Any advice welcolme.
<a><img></a>
http://i1106.photobucket.com/albums/h369/jackal37/WP_000278.jpg
http://i1106.photobucket.com/albums/h369/jackal37/WP_000279.jpg
![smokey_gti in the usergroup ‘Local’ smokey_gti in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
you can mount them the right way up with the scirocco 16v handbrake cables, but you may have to cut 10mm off the end of the metal tubes under the car. basically cut right back to where they are are stuck to the floor pan you'll see what I mean
