Steel sump turbo return
(In Topic #146399)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/300520111797-Copy.jpg)
![ShaunyC in the usergroup ‘Local’ ShaunyC in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
What fitting would i need fot the turbo return on a mk2 tdi steel sump?? (1/2 BSP???)
Thanx Shaun
\/\/ The beast to be…!!!
(loads of pics) \/\/
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=95838&highlight=
SSC ELECTRICAL
SSC ELECTRICAL
![ebo in the usergroup ‘Local’ ebo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
I finally got some k04 lines.. oem oil and custom water… but oil feed dosent match the tdi oil filter essay.. was hoping i could chop the banjo off and put my own bit of braid with banjo on? but apparently it's under a lot of pressue and a jubalee wont hold???
As for the oil return wish i got just a standard steel sump and drilled a hole to suit where the pipe flange is… bit of a faff now choping and putting braid between.. not under so much pressue tho???
Then the water lines… lol these custom lines seem to foul either the oil bajo to turbo or the actuator thing…
I'm getting bretty p*ssed of with it all now! everything seems to be a pain in the ass!! even just trying to get some AGU coolant pipes to see if they suit?? Going through paypay resalution sh*t now
Ooo forgot to say the oil return seems to be in the way of the down pipe and the bracket that holds the turbo is usless
Scowered Here, clubgti, vortex, fortude, ed38, google, youtube any other resorce, no info!! as you probably know..
Its been done before but i guess people don't like to give secrets away!! lmfao
Other than that its all hunky dory…
Might take up sewing instead??
SSC ELECTRICAL
SSC ELECTRICAL
Been told i could cut out and replace the flex on my aeb return pipe but the guys not a reliable source so i got a agu one lmao Gonna make my sump this week there isnt much info avalible information on modifying a 8v sump
What did the turbo come off of? I got ko3 off the mk4 aswell guy chucked it in for £20 so thought why not have a spare.
Coolant wise i think your meant to use a laguna top hose and a mk2 8v bottom for rad ill let you know if metal mk4 lines fit.
Same her next time im buying the easiest engine for whatever creation im makeing.
We all love a bitta sewing
I've offered my sump up and it looks like if you had the 8v sump.. all you need to do is drill 20mm?? hole in the back right hand side then a couple of 6mm holes tack a couple of studs from the inside gasket on outside, then can use the standard return pipe?? I would change mine but i've welded baffles in already
Not sure what the turbo came off.. but its a k04-023.. did want a k03s but couldn't get one.. kind of the same with the engines.. started as KR conversion!!
Yea i've found bits on the rad houses but its the actual plumbing, as simple as it is i don't know what i'm looking at!! can i use the aeb stuff or agu or custom my own system?? God knows lol.. Yea if you cover that part would be good to hear what you did!
I told mam i'm going to put some better motors in her "Singer" for my next project! haha
SSC ELECTRICAL
SSC ELECTRICAL
What sump have you got? Mk3tdi seems a direct swap except you would then need a mk3 return pipe. Also likeing your baffels may need to knock some up when im doing the oil feed.
I was looking for a kr for a while and ended up with a aeb funny how the world turns lmao
Im planning to find my haynes or more proberely bother someone on here lol but at the minute im guessing that i may have to draw myself a picture lmfao
Rubber pipe plan.
Pump - bottom of rad
Top of rad - t piece
Rad breather - expansion bottle
T piece - top engine pipe and expansion bottle
Top engine pipe - heater matrix
Heater matrix - expansion bottle
The metal pipes are a different story im still to look into em i know it uses a oil water cooler but what exactly they do i still have to find out.
Im guessing the breather on servo goes to the passenger side of inlet
But i need to investigate the rest … Lmao
Yea is a mk3 or mk2 tdi sump think there both the same… Thanx
Haha yea.. great minds think a like! so do the not so great one's!! lmao
I tried to do that sort of thing fom VAGCAT diagrams.. i did one for the AEB and one for the AGU weather there right?? lol see if i can find them…..
AEB..
Water pump side - T for waterjaket - engine end junction
Water pump bottom - rad bottom+expansion tank - rad top - T for turbo - T to expansion - T for water jacket - engine junction
?'s
matrix feed, return
AGU..
Water pump side - T for turbo+expansion -T for water jacket - *T to junction A - matrix
Water pump bottom - Rad botom - Rad top - junction A - *T on metal pipe+expansion+engine junction - water jacket+matrix
Because the AEB metal pipe and engine junction was no good for the transverse set up I was trying to compare both systems and come up with my own… main thing to make sure the breather was at the highest point of the system..
Then i realised if i adapt the metal pipe to suit the pump side the AGU set up would work?? and thats where i was at waiting for the bits to see if it would work… Strangest thing, why isn't there any answers to this conundrum!?!?
Also with the water jacket you have to turn it front facing to avoid the front engine mount so the pipe's wont fit any way!! lol
Good call on the servo.. i'd forgot about that.. isn't it a vacum of some sort??…..
just had a goose and seems it's fed from the intake manifold so no need to worry at this stage
Ahh.. i get what you was saying now!! lol
Together we might make it throught this!! lol
![:rockon:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/rockon.gif)
SSC ELECTRICAL
SSC ELECTRICAL
finialy im back to the golf planning on takeing the agu sump and copying where the return feed is my mate was telling me about converting transits to tdis doing the Same but reckoned you could just seal it and it would be fine without being bolted as the returns are low pressure… Still getting bolted lmao
Im also supprised no ones shareing diagrams for what goes where. Ill pm you my email for the baffels diagram.
On the move so better start paying attencion to what im doing. You had any progress?
Yea think it would be definetly better bolting the sump return looks quite easy tho as long as its out the way of the downpipe?
Did you recive the emaill??
Haha yea best mate, wouldn't want a lampost to jump out on ya aswell, hehe..
Not much to report, got another set of AGU coolant hoses on the way wich is hopefully in better condition.. I'll let you know if they work
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
With anyjoy because im gonna use the golf unit itll go the other way but ill keep you posted anyhow
Noooooooo lol nothings easy like found a exit hlle on my back diff so the jeeps again doa near had one free last night but it was a ten spline instead of my 24 (fg£&@**+^#) swapped a axel allready killed my engine lift total mission like.
Gotta get the mrs from work ill be back
Cheers mate would be good to fathom it out?? i must surely have enough ppe now to come up with something and just do away with the solid pipe, or only use parts of it??
Haha it never rains but it pours ay ebo you must feel like pulling your har out!! lol
A couple of good threads on another site for what goes where… Clicky , Clicky
Richard asks alot of good questions that i've bumed info from
But with it all relating to AGU it is different but the same concept?? i suppose? lol
SSC ELECTRICAL
SSC ELECTRICAL
![thickfreakness in the usergroup ‘Local’ thickfreakness in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I've just done all my turbo lines for an AEB block and steel sump. I've just used the agu feeds, with alot of cutting and jubilee clips. Its abit of a bodge but seemed the only way. Hopefully the clips will be strong enough to hold!!
I can try and get a pic up for you if you want mate. For the steel sump, I've welded a boss onto it for the return and joined using some braided hose.
I've gone with a K04 turbo so needed the lines to suit that.. but as you say they need adapting and i just spent a chunk of money on these lines so don't facy chopping them up, lol.. I can custom make some! i've priced all the bit's and by the time i'd baught banjo bolts etc from audi it will work out cheaper than OEM hahaha love going backwards
Yea i made a boo boo getting a tdi sump
SSC ELECTRICAL
SSC ELECTRICAL
