1.8 KR on ZX9R Bike carbs - How much power
![Lee_dub in the usergroup ‘Old timer’ Lee_dub in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
lhasadreams said
On what factual basis can you claim that k-jet is garbage ?
Theres a reason Mechanical fueling has not been used in cars for years. Carbs are still used today. go figure
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
Its not the full story, or a rational reason. Limiting it to cars, all cars these days use electronic FI for emissions reasons. In the same way EFI can meter fuel precisely enough to meet emissions requirements, it can be "chipped" or altered (indeed the manufacturer will do this at wide open throttle conditions, but not too much) to achieve best power or torque.
Mechanical FI, ie K-Jet as fitted to the Golf GTI, can't be tuned in quite the same way but it can be tuned, and achieve the optimal AFR for best power. In itself, it doesn't impose any particular restriction on the engine breathing either.
Carbs once properly set up, can also produce the ideal AFR for best power. However, since K-Jet can also be set up for best power, there is no gain to be made.
Once you start considering things like warming up, running on part throttle, etc then both carbs and K-Jet mechanical fuel injection are not as good as properly set up electronic fuel injection (especially if closed loop lambda feedback, which pretty much all are these days). However, K-Jet is better than a carb during warm up and part throttle. That's where carbs fall down, and why they were eventually replaced.
![Avatar](https://i176.photobucket.com/albums/w172/collismail/DobbyMk1120x120.jpg)
![Brutal in the usergroup ‘Regular’ Brutal in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Today is a good day to die, but tomorrow would be more convenient
lhasadreams said
And they are ?
What cars leave the factory today with carbs ?
I would be surprised if you could find one that is not single or multipoint injection.
Still would like to see the power plots though !!
didn't say cars specifically did I?
Lots of bikes still use carbs. Anything mechanical cannot be as efficiant as EFI but k jet suffers badly with flatspots, no overrun cut off etc etc
Kjet = crap FACT!!
Oh by the way I should probibly add I run a 2.0 16v on kjet! How ironic!?
Brutal said
Well as per reading all the above, My statement about 90bhp and the scoobie were completley hypothetical I thought that was apparent, the idea was to scope some conversation which in a way it did, my main point was to extrapolate as to paul_c's comments "what is power", the truth of the matter is that my mk2 must have been pulling at least stock and with general rule of thumb and good tuning the carbs in the mk1 should make a difference, the figures on the graph show a similar result seemingly to paul_c with great result to 5.5k then an amout of leaning off that we couldnt resolve. however whilst driving it yesterday after the work was done the acceleration to 7.5k and climbing was phenominal. I do not however believe the result on the graph. to much power is going forward, as stated I have had to drive fast cars hard in the past for my job and have owned motorbikes that get to 60 in under 4 seconds. This car is more than the sum of its parts!!!!
Just post the results!!!!
I dont think it is right.
There you go!!!
![Avatar](https://i55.photobucket.com/albums/g160/r1-matt/mAtts.jpg)
![Matt in the usergroup ‘Old timer’ Matt in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
is that at the flywheel or the wheels ??
geez if thats all you get mine will be out by saturday !!
I bet you a tenner that if you take out the KR and put in a g60, we went toe to toe you would not get past me ….. my point being THE FIGURE ISN'T RIGHT!!!!!!
Hence the starting of this thread in the first place.
Are you going to believe the figure or the road!!!!
what did the guy at the rollers say to you ? his rollers can't be that far out surely ?
![funk-star in the usergroup ‘Local hero’ funk-star in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Thats at the wheels then for sure.
Built my old mans westfield lump which was a vauxhall 2.0xe lump, coscasthead, apr bolts etc, running jenvey throttle bodies and omex ecu.
RR @ 192 @8K at fly think the at wheels was below 140. which is still bonkers in a 600kg car lol
Now my mate has a dax with a 190 bhp bike lump running light weight chassis which is aroung 500kg and that thing is savage in comparison?
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
but fair play to ya mate if it is running 180
Matt
Matt i did spend a lot of time researching this project before I took it on, and the amount of work wasn't minimal really. I just haven't got the cash at the mo for the exhaust and I dont see the point of bunging Schrick/kent cams in at the mo, I wanted to get the engine in and running right first before I went down that route., using the "if it aint broke dont fix it" train of thought, cams and exhaust are easy to do - they can wait…
Website Manager
I would love to see how the head was ported and polished because that is a serious gain in power from just head work.
Would expect to see a 14.5 sec quarter mile with 180bhp on tap - you going to run it on a timed strip ?
Have you got the power plots ? What sort of torque was it developing ?
This was my 8V G60 plot from 2007, it had a ported head, standard cam, supersprint downpipe and a 68mm pulley/chip - It was a 1H Rallye engine so 1763cc
A couple of chips were tried, used the Jabba one in the end…
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fhomepage.ntlworld.com%2Frichard.daniels%2Fmk12007%2FG60MK1Plot.jpg)
Again my real point is could the graph be wrong, I am certainly not trying to compete with anyone I wanted to see what results other were getting with the same setup before shouting my mouth of but nobody has yet given me that answer.
I'd be more worried that the head work hasn't produced any sort of gain either. Who did the work, and what was done? Its something of a skilled art, its not just a case of removing lots of material, its the right amount, and where it comes off from.
Also normally on rolling roads they measure the inertia as the car freewheels through the transmission back to idling from full revs, take one from the other to get flywheel bhp - its worth doing this as the transmission losses do vary from one car to another, although you can normally assume a percentage etc.
![](https://i176.photobucket.com/albums/w172/collismail/ScanImage002.jpg)
I am not worried about what headwork has been done etc etc, I just wanted to know is it possible the rolling road figure could be wrong, I used to race minis as a kid I have built countless engines for personal use over the years from bikes to cars, I used to repair aircraft engines as a lad and served my apprenticeship doing so. I know carbs dont give any gains themself but they provide the vehicle with the means to do so.
My question….
Can these figures be wrong????
Looking forward to the answer
