brad mole's mk1 golf project
![dano999 in the usergroup ‘Local’ dano999 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
HOPING TO GET MY FIRST MK1 TOMORROW,
Instagram Firemandan1
![RobbMK1 in the usergroup ‘Newbie’ RobbMK1 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Can you tell me what that aluminium paint is called and where is is from?
![brad_mole in the usergroup ‘Local’ brad_mole in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
this is the stuff, i got it from here too, its the aluminium colour you want, it seems really good when it goes on, but mine had all reacted and wrinckled so im unsire whether id class it as good or not, maybe it was something i done, or didnt do
brad_mole said
http://www.frost.co.uk/automotive-paint/engine-enamel-paint.html
Thanks for the reply mate, The finish looks really good on the parts you used it on..
Did you use any rust killer or primer below it?
![alfie in the usergroup ‘Old timer’ alfie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://farm6.static.flickr.com/5269/5561299223_870a72c7f4_z.jpg)
SNAP… Almost, lol
![](https://farm9.staticflickr.com/8460/7955455932_4524dd642e_b.jpg)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.alexblundell.co.uk%2FSIG.jpg)
Wanted: Front Bumper, DESPERATELY NEED A DRIVERS WING!
MY Build Thread
My Facebook Build Page #Project83
![Avatar](https://i2.photobucket.com/albums/y23/redpetemk1/avtar.jpg)
![redpetemk1 in the usergroup ‘Old timer’ redpetemk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I wrapped my steering rack boot, been using it for a few years now, and never a problem, and my stainless manifold isn't wrapped and it gets damn hot!
As for the cooling, have you got it sorted? I thought about top fill etc, but I wanted to use mine hard and as much as poss, so my thinking was to go for what they were designed with. Even then all valvers run hot, (esp when your temp gauge is lying to you!!)
Look forward to seeing it finished :wink:
basicly heres what happens, the car takes a good few turns before it starts, then when it does eventually start it will just stall straight away, do this a few more times and it will eventually stay running but the revs go up and down constantly and sounding like it wants to stall, if i rev it it kind of kills the revs and wants to stall, leave it a bit longer and it gets better, eventually it will stay running and seem ok, but then when driving it it has no power at all.
ive been told it could be a temp sensor not telling the ecu that the car is cold so its thinking its warm constantly? which explains why it runs ok when its warm, but dont know why its lacking power, also the radiator still boils over so not sure if i should get a bigger one now.
anyway, may as well stick a few pics of the small updates
i added more aluminium tape around the boot to help reduce the risk of burning it
![](https://farm9.staticflickr.com/8333/8100912541_aed13b9ef6_z.jpg)
brad moles mk1 golf by bradmole, on Flickr
got a mini fire extinguisher which im going to mount in the back somewhere
![](https://farm9.staticflickr.com/8326/8100910397_53401ace80_z.jpg)
dash fitted
![](https://farm9.staticflickr.com/8326/8100910141_59372f1094_z.jpg)
and put an old steering wheel in for when it gets MOTd
![](https://farm9.staticflickr.com/8052/8100922246_ccf0bcac82_z.jpg)
i brought the car around to the house to give it its first wash in almost 2 years of owning the car, it felt good to give it a clean although itl take a few more good washes to get some of the muck off thats been stuck on there for so long, makes me feel a bit better seeing it looking clean for a change
![](https://farm9.staticflickr.com/8186/8100921116_13728c0071_z.jpg)
![](https://farm9.staticflickr.com/8190/8100910811_1faec4f211_z.jpg)
![](https://farm9.staticflickr.com/8043/8100911417_c655059f0b_z.jpg)
![](https://farm9.staticflickr.com/8333/8100911951_f4af53c528_z.jpg)
![](https://farm9.staticflickr.com/8049/8100912303_2380587006_z.jpg)
![](https://farm9.staticflickr.com/8054/8100911169_84fd3311d1_z.jpg)
Its been trailored away for winter now to be stored in my mates garage so there definitly wont be any more updates til after winter unfotunatly
but look what i bought
![](https://farm9.staticflickr.com/8471/8100909751_6fa833acd7_z.jpg)
![](https://farm9.staticflickr.com/8326/8100909919_fa273bef50_z.jpg)
dont get too exited though im not sure if im going to fit them, still undecided at the minute i just want the car driveable before i start messing with this kinda thing haha
![Raps3 in the usergroup ‘Regular’ Raps3 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
As for you problems, replace the small sender on the side of the head or plug into another one of the three, plus the bigger brown temp sender (brown plug) could be duff. As your running the ISV i'm not sure a problem with this could cause what you describe? Check wiring for breaks as well etc.
When I first started mine it was a bit tricky getting it all sorted. I brought a Gunson co2 tester as a guide to get the mixture somewhere near right and check the timing, (6degress std kr) there will be a mark on the flywheel for it. Then just tweak the mixture/idle and timing until it's all somewhere near. A garage could set it more accurately later on at MOT time.
I did spot your post in the for sale section, kr turbo eh……
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/glr.jpg)
![richievr in the usergroup ‘Old timer’ richievr in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
looks sweet as matey, even on your temporary wheels…..
likin the recaros, bay look awesome, roll on next year i guess when she comes back out of storage..
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/stanceworks_by_zoptekracing-d4tmb2e.jpg)
![lewis_86 in the usergroup ‘Local’ lewis_86 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mk1 golf 1.8 8v = sold
mk2 golf gti = burned out
mk3 VR6 = wrote off
mk2 seat ibiza gti = sold
mk5 jetta tfsi = stanced and slammed![;)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wink.png)
Mk1 golf = garages and butt naked
mk3 VR6 = wrote off
![browner01 in the usergroup ‘Old timer’ browner01 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
![](https://i888.photobucket.com/albums/ac81/browner01/mk1-1-2_zpsfe05207a.jpg)
