Mk1 g60
(In Topic #146810)
![farmboymatt in the usergroup ‘Regular’ farmboymatt in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Mk1 g60
What throttle cable do people use?
What expansion bottle is best? mk1? As this has the mount there already?
Mk1 g60 in the making
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi47.tinypic.com%2Fmvrtw2.jpg)
![CabbyBrad in the usergroup ‘Old timer’ CabbyBrad in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/224image.jpg)
![Mike 16vG60 in the usergroup ‘Paid Member’ Mike 16vG60 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Mike 16vG60 in the usergroup ‘Old timer’ Mike 16vG60 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
there is a good thread on Edition 38 for mk1 G60 builders that's worth a look
http://www.edition38.com/forums/index.php?showtopic=372041&st=760
I think the Pacet 12" slimline fan is what's recommended - apparently cheapy ebay ones are a waste of money. Some good tips there on radiator/ intercooler options too if you've got time to read through all 39 pages!
Also might be worthwhile looking on dubforce
Been fitting the driveshafts today and looked at the linkage. I've got a mk2 16v gearbox on her so this will be rod change. How do I hook up the linkage? Obviously the bracket on the mk2 gearbox is different to the mk1 bracket but the mk1 bracket doesnt seem to fit the 16v gearbox, I was only having a quick look so might have missed something. Any advice?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
farmboymatt said
Thanks that was what I was thinking, another question. How important is the lamba probe? How exactly does it work. A few people have said I don't actually need it, how much does it effect the ecu?
It always worries me when people are doing a conversion and they ask questions like that - because it shows a lack of research before undertaking the task - a good way to throw money down the drain !!
The Lambda probe measures how efficiently the fuel is being burnt. Ideal is 14.7:1 air to fuel ratio. The probe on the G60 is a narrow band one, so only measures a small distance around the 14.7.
On the Digifant ECU the Lambda Probe signal is used to allow it to go into a closed loop mode for cruising, so if it goes too rich or lean within the narrow band it will try and correct the air fuel ratio. However if the signal is not present the ECU will not be very happy at all.
So you could run without it if you could tell the ECU to always use the map that it has and not adjust for a Lambda signal - some one like Jabbasport can do that, but it is a bit of a hack.
If you want full control of your setup then you need to consider an aftermarket ECU like Emerald, Omex, Megasquirt etc…
Thanks for the answer it was the best explanation i've heard, surely this is research? To be honest mate doing any kinda mod on a car is like chucking money down the drain (especially if you pay someone to do it), you'll never get it back when you come to sell it. Best option is to buy a car that someone else has spent a lot of money on.
I feel getting your hands dirty and taking things apart to figure out how it works is the best form of research but then I always think agriculturally, that anything is possible.
many thanks
matt.p
Website Manager
Buying a ready done car removes all the fun.
I daren't add up all the money I have spent on mine since 1993 !! And it has not stopped - lol.
Good luck with the conversion. I like supercharged engines, currently running a 16V Lysholm :-)
The Digifant ECU is a bit fussy if it is not getting all its signals and will drop into a limp mode. As well as the Lambda there is a knock sensor (not a particularly good one mind) but it will allow the ECU to adjust the spark advance depending on the fuel grade you use. The other critical ones are the coolant temperature and Air temp/CO Pot. The throttle housing also has fully closed and wide open throttle micro switches that should be checked for continuity.
Is anything else appart from the rubber plug supposed to hold it in the bulkhead. It keeps coming loose at this point. Also, theres no spring on the throttle pedal is there? Been so long that i've worked on the mk1 I'm struggling to remember.
Website Manager
Website Manager
