Innition Lead and Injecton hose arrangement
(In Topic #146633)
I'm setting up my 16v engine,
In which order are the ignition leads needing to go (ABF cap btw)
And also, the metering head ports go to which injectors??
Thanks!!
i dont know much about timing etc.. gimme the basics if you can
What you need to know about timing? You had the engine apart? If not and all turns freely, turn the dizzy cap to 12 o clock and adjust accordingly if sounds rough (turn it forwards and backwards you'll here when engine likes it) make sure dizzy is on the right way to the cam shaft also as its a tapered end
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
the line on the dizzy body should point to tdc
if you take the green bung out of the gearbox there are 2 timing marks on the flywheel. a dot for tdc and a diamond shape mark next to it for setting up with a strobe timing light.
there are also the timng marks on the cam pulley and crank pulley and there are dots on the cam sprockets in the rocker cover that should line up with the head
