NO SEAL ON ROCKER COVER
(In Topic #146514)
![Avatar](https://i1263.photobucket.com/albums/ii634/trofski/IMG_0292_zpsf26735b8.jpg)
![trofski in the usergroup ‘Regular’ trofski in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I took my rocker cover off to clean it and replace the gasket(cork). I have cleaned it all up, but just cant get a seal. Ive tried it loose (hand tight) at first and then nipped it up to snug, but the back passenger side keeps dripping oil. Im finding it hard to get hold of a torque wrench that goes down to 7 ft lbs without spending £80 to tighten 8 nuts.
I also tried some sealant today, good stuff, but no joy.
any help here would be greatly appreciated.
its a mk1 GTI cab 1991 G reg
Also, since doing this the engine seems to dip a little and the exhaust is quite different, whats the link that causes this?
really appreciate your help
Dom
![](https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/307762_10151044514960785_1841676575_n.jpg)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi47.tinypic.com%2Fmvrtw2.jpg)
![CabbyBrad in the usergroup ‘Old timer’ CabbyBrad in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/VW_golf1_small.png)
![Shughy in the usergroup ‘Moderators’ Shughy in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Shughy in the usergroup ‘Paid Member’ Shughy in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Shughy in the usergroup ‘Regional Hosts’ Shughy in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Shughy in the usergroup ‘Local hero’ Shughy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Sometimes a missmatch of gasket & stud types can throw up a leak.
The early cork gasket is used with shouldered studs to prevent the gasket from being overtightened.
The rubber type has metal washers built into the gasket and studs have no shoulders on them.
I replaced mine not to long ago for the rubber type.
Check the studs first before you buy.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
all done...
I got it all done today, bought the mk3 gasket, changed the studs over and boom, sealed first time without sealant.
When I changed the studs, I noticed that the back right stud wasn't screwed all the way up to the shoulder, and this was the leaky corner… I'm glad this happened as im happier with the rubber gasket now… took her out and she flies…
![](https://i1263.photobucket.com/albums/ii634/trofski/th_IMG_0280_zps5fc8db04.jpg)
I think I may have screwed it out a little more when taking the rocker cover off but it was definitely not all the way in…
![](https://i1263.photobucket.com/albums/ii634/trofski/th_IMG_0292_zps3d206b90.jpg)
it is...
peace
![mk1cabnel in the usergroup ‘Local’ mk1cabnel in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
help at hand
still leaking...
After sealing the rocker cover last week, I still have a small leak, wheres the next point to check? it seems to be dripping from 3 points underneath which tells me the leak must be above the sump… oh i don't know… I have de greased the engine and just cant find it.
Any advice welcomed. cheers
Dom
here we go again
thanks for the advice, Ive had it off and there was a little oil but when i degreased and let it run for 15 mins i saw nothing leaking, most of the oil is on the gearbox side of the engine but i cant see it leaking from that side of the rocker cover, it seams lower than the rocker. but above the gearbox, i wonder if i have two leaks? gearbox and engine, its also hard to get into 1st when warm…
it looks pretty oily around the oil temp sensor, or maybe the plugs?
At the moment i put about half a ltr every 2 weeks in her just to keep her afloat.
help
![CraigSherriff in the usergroup ‘Paid Member’ CraigSherriff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![CraigSherriff in the usergroup ‘Old timer’ CraigSherriff in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Shughy said
Might need to change to the rubber rocker cover version. Its a mk3 one. Need to change the studs too. Its a better fit and all snug with a little sealant. Also check your rocker cover is not cracked or bent in that corner.
Hi,
I need to change my cork gasket over to rubber, do you have a picture of what the finished article looks like? I'm not sure what bolts / studs / shoulder thingies I need to replace go like?
I have the parts all set, ordered from VW Heritage.
Also,
Don't suppose anyone knows the torque settings for the new gasket? Cheers.
1990 - Cabriolet GTI 1.8 (DX)
for torque you just wind them all down with your fingers till they bottom out, then nip lightly with a small ratchet/spanner. The rings in the rubber gasket will stop you deforming the gasket, its just a case of dont tighten the nuts so much that you shear off the studs!
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/pie100.png)
![:offtopic:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/offtopic.png)
(It's in the top left "pot" of the picture, all the rest were pretty empty
![:|](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/mellow.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1480554/BCBAB1AF-E3B4-4321-926A-D8BAE61349F1_zpsuz22t7oa.jpg)
