Project Sleeper - Mk1 Golf 20vT AEB... Now Runs :)
ShaunyC said
Excelent work fella You'll have to get a vid up of her flying around :wink:
Hopefully i'll get mine back off the ground sometime soon!?!?
P.s. done any good with that AEB right up yet?? lol
Peace out..
Hi Shaun. Yeah i had a vidoe ill have to uplaod in on youtube at some point, it was quite hairy as it just started raining on the test run and i had no windscreen in and the brakes/tracking were average at best
Ill start working on it over the next few days. If you have any questions in the mean time, please feel free to ask.
Gary
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
ebo said
Hiya fella love the build see how the turbo catches the bulk head did you just unbolt it and turn it round?
Yep, thats all you need todo for adjusting I can't quite remember but if you set it up on the car slightly loose and readjust it so the boost pipe comes straight up, it alters the wastegate position. You may need to cut the end off the wastegate bracket so it sits flush again
I drilled a new hole in the Wastegate holding bracket to accomadate this and also welded a small piece of metal on the other end of the wastegate bracket ( with a hole in it ) so it could be fixed back securely using the existing tapped threads on the turbo.
Hope this wasn't confusing
the detail is awesome
Just wondering how did u fit the gear shifter to the car cuz I'm gonna be doing this soon (cable change) but just a bit unsure how to fit the shifter
Maybe u cud shed some light on my situation
Also how did u fit them through the bulkhead? I.e wat size grommets etc etc
Cheers matey
Dan
The pictures are no longer showing so i had to piece things together in my head but I looked at the video on YouTube and it looks brilliant, bet you're proud!
I'm doing a conversion at the moment and it has helped with a lot..
Well done!
Thanks for the great replies everyone. This is a video when she rolled out the garage for the first time.
Hope everyone is doing well here. I still own this car although she is currently getting a bit of tlc after being garaged since we had a child.
