I got me a Golf gx
![MK1G4V in the usergroup ‘Regular’ MK1G4V in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I got me a Golf gx
Is there a way i can protect the seams without it?
I thought of running a fingers worth of filler or even fiberglass over all the seems and sand them down for a nice Finnish, Only I'm wondering if its likely to crack? Sounds stupid but Is there any movement even slightly likely to happen under the bonnet that might crack the filler/fiberglass?
Cheers Gav.
MK1G4V said
Right so iv'e removed all the nasty seam sealer from everywhere under the bonnet I know its there for a good reason only If i can help it i dont want to put it back on.
Cheers Gav.
Anyone have any suggestions?
![charlie-says in the usergroup ‘Local’ charlie-says in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
The thing about the sealant is that it is waterproof and flexible. How come you don't want to put it back? I'm doing a full strip down resto on my VW Derby and whilst I admit seam sealant isn't the nicest looking of things, it serves a very valid purpose. Surely vibration and heat from the engine would mean that filler or fibreglass wouldn't last long?
What about masking either side of the join then painting a neat line between? Looks better than just slapping it on I find.
charlie-says said
I know that on a polo (I'm assuming it will be the same on a golf) that the sealant helps the bonnet skin to retain it's shape. A friend got a bonnet acid dipped and the sealant coming out deformed it.
Right I see only when I mentioned under the bonnet I actually meant in the engine bay itself like all around the turrets and all the way down to where the drive shafts come through those holes (not sure what there called) Its where water would run after the drainage holes in the shuttle tray I think its called? The only reason I don't want to put it back on is as you mentioned Its bloody ugly stuff
I did think that there might be a chance of filler or fiberglass cracking Not so much from heat It shouldn't be near hot enough to do damage but vibration and slight flex might not help?
That said I see more and more smooth engine bays popping up presumably there a couple of tubs of filler involved In that process, I wonder how those folk get on?
Cheers GAV.
So I have had a change of heart after my mate decided to brake his seat ibiza cupra
Updates asap!
![funk-star in the usergroup ‘Local hero’ funk-star in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Lol
funk-star said
Nice use of king size rizla with sections missing ;-)
Lol
You Dont miss much mate
funk-star said
Jamacan style? Lol lol
Lol Ya mon!
