Car leaking! Please help...
(In Topic #146008)
![RobbMK1 in the usergroup ‘Newbie’ RobbMK1 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I have noticed ALOT of water in the drivers side front and rear footwells. After removing the door card I sprayed the hose on the handle and noticed water was leaking through that.
I have since changed the handle gasket but now water is pouring in through the window seal at the bottom of the window.
Is this a common problem and what do I have to change to fix this?
Forgot to mention, my car is a 1984 two door tintop
Imagine the roofing felt going into your gutter on the house.
If the seals are shrunk and worn then new ones will help.
I have cleared out the drain holes they were full of dirt but the odd drop keeps getting through the gap between the bottom of the door card.
The membrane seems intact and stuck well..
Is it worth just changing the scraper seals?
![Avatar](https://i1099.photobucket.com/albums/g400/Pearcestu/bad48f7d-f423-46ef-8139-0695961c6e13_zps7e522994.jpg)
![pearcestu in the usergroup ‘Paid Member’ pearcestu in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![pearcestu in the usergroup ‘Old timer’ pearcestu in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Lee_dub in the usergroup ‘Old timer’ Lee_dub in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Take the membrane off, reseal it and try again mate
