smokey 1.6td
(In Topic #145663)
smokey 1.6td
i hear pump timing is a common issue could it be this?
http://img.photobucket.com/albums/v318/tizo/Untitled.jpg
is.
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
If you turn the fuel screw up, it will give out a big puff of black smoke before you're on boost and maybe while you're on boost if it's running LOADS of fuel but out little 9mm pumps tend not to be smokey once the turbo's going.
First thing check pump timing! As white smoke either indicates retarded timing or a dead turbo .
Was it on gumtree…..
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
