1983 5 door 1.8t conversion (NOW FOR SALE)
peterg60 said
nice turbo choice. is your can 15mm outlets ?
Yer turbo will see me 260bhp witch is enough without a LSD lol
Yes 15mm in/out lets 16mm pipe 3m of and a 15mm t piece only reason is the pipe will have to fit over the rocker cover outlet witch is 19mm so it will be a tight fit but then the pipe won't be hanging off the rest of the stuff i.e can ect
Pretty simple but i got to say if you do this mod be very gentel when removing the not needed pipe from the crank breather as they are very brittle and snap like mine did.
Parts needed :
- catch can with 15mm in and out let tips.
- 3M of 16mm piping oil/water anything like that.
- 6 1" D clips (the catch can one's will be to small)
- 15mm T peace
- flat head crew driver
- Alan key's
- Stanley knife or a sharp knife
Basically you need to remove all the breather pipes and simplise it as it is in the diagram you can remove the hokey puk (tip breather) from the intake pipe and just block that hole up and direct the pipe down the back of the gear box as i did just gets rid of all the tight bunched up parts around the DV.
Any question on this mod just as took me half hour to do.
Here is a pic of here at the min
Also sprayed the intercooler black not so showie now
simongolf83 said
Hi mate how's it going I saw a car like yours in rugby on Sunday afternoon with the bonnet up was that you?????
Lmao hello mate yer that was me and the Mrs the fan had packed up on the rad so she got hot and lost water.
simongolf83 said
Was going to stop and have a chat but I didn't put 2&2 together till I got to the parents house. Did you get it going in the end?
Yer got it sorted in a fashion thanks to Paul coming to my aide, think i need a new fan or bigger rad. Should of stopped you could of got wet too lol
simongolf83 said
I had the kids with me? Apart from the fan it's working fine then?
Yer just need to sort the fan out then its being mapped
Some pictures of my new fan and modified mk1 shourd
Awsome Neuspeed 108f thermostat link
neuspeed 180f 2pin fan-switch link
Will keep you updated lets hope this sorts my problem out before it go's for mapping :?
how do you find the cable clutch mechanism ? what cable did you use? I am thinking of using the same setup on mine but have read mixed opinions on it.
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
