Oil light and buzzer help plz
![bucket in the usergroup ‘Local’ bucket in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
rubjonny said
argh chocolate blocks! the devils work. you may have a dodgy contact in them, if it was me i would cut right back and solder in fresh wire.
did you double check the ratings on the old sensors that you took out, as im not sure if the small block ones are slightly different ratings
Yeah i assumed there was a similarity, the haynes book of lies says 2 bar, is minimum at 2000rpm … so the new high pressure would be correct, the one that causes it to buzzing to occur
the old has no ratings on, so a little bit confused now
