Ignition live fuse?
(In Topic #144386)
![Avatar](https://i1165.photobucket.com/albums/q589/punkshnitz/4ff01a4d.jpg)
![Shnitz in the usergroup ‘Newbie’ Shnitz in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Ignition live fuse?
Is there anything along the lines of an ignition live fuse? Any help would be greatly appreciated!
Wayne
Its possible you have burnt an important wire that was unfused.
Don't like the sound of the blown a wire thing!
![Lee_dub in the usergroup ‘Old timer’ Lee_dub in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Ignition live is still getting to your fusebox if you hear the relief relay and horn relay working
with dash dying look at the earth for the cluster, if its got an mfa it will earth to the side of the head, look for any brown or brown/white wires. if not it earths behind the fusebox, probably to the earth claw above the fusebox.
finally try adding a thick/braided earth from the rocker cover to one of the coil mounting bolts, this sometimes helps with a dodgy cluster
