16v vacuum pipe help?
(In Topic #144127)
![brad_mole in the usergroup ‘Local’ brad_mole in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://farm8.staticflickr.com/7075/7243042424_ebb33af0ff_z.jpg)
brad moles mk1 golf by bradmole, on Flickr
![](https://farm6.staticflickr.com/5280/7243041986_5f2b3cbd0d_z.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1206425/SSA50722.jpg)
you need a pipe like in the pic with a 1 way valve mine has 2 smaller pipes coming off this. 1 goes to the ecu and the other loops round to the 2 things on the airbox which you dont have so could be blanked off. there is a 90 degree piece of rubber hose that goes to the back of the manifold
looks like you have the fifth injector housing on the wrong way but i suppose you could link it up somehow
are you using the isv from a mk2?
also does your bonnet shut ok looks like it will be a bit close to your metering head
i put the mk2 metering head on a mk1 gti airbox and cut half the bottom section off and put 2 notches in that sit on the chassis leg seam
