Chortles Project Green Rivage. New roof time....
Chortles Project Green Rivage. New roof time.....
The Velcro wasn't much. the most expensive bit was the press stud kit, but it comes complete with all fixings for 12 sets of press studs plus the tools to apply, that came in around £6.00.
![boyle_sbd in the usergroup ‘Local’ boyle_sbd in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mk1 golf - resto
mk3 polo breadie - daily banger
dal said
Are you going to change the needles colour on the dash back to white, only the Sportlines had red needles?
Davie
Thats wrong info.
BigNormRivage said
Davie
Thats wrong info.
You sure? I thought it was only Sportlines with the orange needles? If your clocks are original orange needle sets (as in a genuine clock set rather than painted needles) the fascia panel around the clocks should be a dark silver/grey against the black clock faces, rather than black on black.
1.8T CABBY
1.8T CABBY
Ive since been in touch with the original owner of my car (about other bits) and the needles were orange from factory
BigNormRivage said
There was a thread about it before and quite a few people with Rivages knew there clocks were original and had orange needles.
Ah, cool, can't remember seeing the other thread. Possibly VW using what was available at the factory towards the end of production?
Good to know you've traced back to the original owner. 8)
Bringing it back on topic, yours is looking great Chortle, you've done a nice job on the deflector!
1.8T CABBY
1.8T CABBY
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/23EE18677-F851-49A4-B9AD-29E94F70B058.jpeg)
![Red-or-Dead in the usergroup ‘Regional Hosts’ Red-or-Dead in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Red-or-Dead in the usergroup ‘Local hero’ Red-or-Dead in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
New rubber rocker gasket fitted at the AGM.
Cheers Glen and Dek.
Going to see jelly next week for some tinkering.
Need to take the clocks out and sort the MFA screen and the broken mile reset stick.
Sorry fella not got back to you.
Pm me a price and I can decide.
Save me a job of going of going round the scrappers.
Rear bumper to do yet, but decided to freshen up the arches with new paint.
(pics to follow)
Whilst at it I picked up a Hirscmann automatic Ariel off e bay last year, mine was snapped on the car when I got it, so it needed replacing anyway.
I noticed the connections were the same on the old ariel which turned out to be an automatic one as well.
So the swapping over should be simples….
turns out that the radio that came with the car never tuned in and I needed an adapter for the back of the lead so it would fit the Ariel socket on the stereo, a quick trip to the motor factors and £2.49 I was good to go, or not. Jelly discovered that the PO had just chopped the cables off and stuck them together with tape so that's why no signal was getting to the stereo.
So the new cable was put in after a bit of a faff.
So just got to shorten the power cables to the ariel motor and that's all done.
So I set about the sorting the clocks out as the MFA was dead.
I had a donor set I was going to cannibalize, but luckily Gav had some bits left over, so had them so cheers Gav.
You can see why it wasn't working blown resistor and diodes..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/03485A8A-EA07-4024-8D9B-070EFEA815A5-235-000000779F6ED762.jpg)
The donor set I put in for time being, so I could use the car, turned out to be dead too. Nothing at all.
So I swapped the Voltage regulator over from the original set and they worked.
Happy days.
I managed to get hold of some new regulators, but these were slightly different. So needed a little work.
Easy to remove one screw and slide out.
![](https://i380.photobucket.com/albums/oo248/chortlemk1/D8041EF6-0281-4F08-9B30-85049539E325-235-000000769B4DE372-1.jpg)
Old regulator at the top. New one with straight legs and one showing how the bends in the outer legs need to be.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/6BCDCD83-138B-483E-8CB6-F38C28CC30BA-235-00000076B5AFF023.jpg)
The new Regulator doesn't have a kink in it like the old one on the back plate, so didn't sit flush.
So just trimmed these 2 black spots down and then screwed the new one in place.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/74ACD1CD-C6B1-41BC-B944-7C780EBB3308-235-000000769393E268.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/2C9E810A-0079-46AD-9932-DCBE4BB4101E-235-0000007C856BCA2A.jpg)
It was easy to swap the mileage reset stalk as it just unscrews..
So clocks all built back up and ready to go back in then I noticed rev counter needle….
I pulled the needle off when I needed to swap the circuit board underneath, now it just hangs down.
Any Idea of a fix anyone?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/F366E262-AE76-4238-AE3A-31CCCDBE8880-235-0000007780722A07.jpg)
So took the wheel arch covers off, to find all this body work glue.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/3012DAEE-5130-4856-9BA4-EF04366CCCF2-235-000000766F3AB306.jpg)
Any idea on whats best to use to remove it?
Just been picking at it really.
Once that's all off, its paint and waxoil before the kit goes back on.
I had noticed my Alarm had stopped chirping and I wanted to know why all the functions bar from the noise worked. I managed to get hold of an installers guide to my alarm and it states the siren housing etc needs a 12V+ feed and checking around with the meter showed there was no supply.
So a new + supply found and sorted and I am chirpping again.
These siren boxes have a back up battery in them also and its common for these to cause a no noise problem too.
So looked for a spare and no luck.
I remembered as a youth the old cordless phone we had, great big Ariel on it, with talk time of 3 minutes lol.
On changing a battery in one of these phones a couple or three times before, realized they were similar, so a look on e bay for cordless phone batteries led me to two 3.6V batteries, although the one for the alarm is 7.2V by connecting them in series, Pos to Neg I will get the 7.2v anyway and at an extra 5o mAh to boot, these were the closest I could find to the origional battery anyway.
All I will do is swap the plastic insulating sheet over and solder the wires together and wrap in some tape and re cable tie them back in.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/9A38BCD6-84C1-4E3E-BFB7-BEE90EA6CE12-235-0000007FBE9799BF.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/69A6D275-79ED-4A49-9936-28B2B76313A1-235-0000007FA743F630.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/80A4AB4E-2480-4CF1-9C44-0CA833AB7E2B-235-0000007FDC249D6A.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/B4422AE2-6C4F-4017-97F6-5AC62184E5BB-235-0000007FFA580EB9.jpg)
No difference in size.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1220303/BEDACAEE-2AD4-487D-A8FF-CABA6F0CF1D1-235-000000900E9CDB1B.jpg)
Once that's done will put the arch liners in, covers on and good to go…..!!!!!!!!
![Avatar](https://i270.photobucket.com/albums/jj96/Bouchay/WeddingRivage3-1_zps3b415af2.jpg)
![bouchay in the usergroup ‘Paid Member’ bouchay in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![bouchay in the usergroup ‘Old timer’ bouchay in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Hope it helps, Bob
Do I need to wind the needle spindle in like a clock spring then hold in place while I drop the needle back on?
Need to experiment really..
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103287&highlight=mfa+secret
I pulled my rev counter needle off using a fork, just slid it under the needle and twang, off it came!
loving that info….will have a play when the other stuff is sorted.
Just need some good weather ahead so I can get painting away, mop and polish the rest of the car, really want to get the roof done before winter I guess..
