Sportline flywheel cover plate, which one fits??!
(In Topic #143180)
I took my 1993 GTI Sportline (DX engine code) into Kwik Fit yesterday for 2 new front tyres and tracking to be done. Whilst there I asked the mechanic if there were any glaring issues underneath. He told me that there was a gap between the engine and the gearbox where the flywhell was clearly exposed and thought there should be a plate covering it.
Anyone know if I am missing a part here that I should look at finding and fitting?
Cheers,
Del
I believe your box will be an 020 code, I'll see if I have my old cover plate kicking about later if you like?
In the meantime someone should confirm for you!
Can anyone confirm that this'll fit for a 1993 sportline?
I couldn't find the code on the car or in the docs. Just found a code for the transmission which was AUG.
Come on peeps help a brother out!
note this piece is a later revision, early cars the tin plate between box and engien was all one piece which made sump removal a bit of a git. so vw lopped the bottom off and made this plate. sump swaps still a git, but ever so sligtly less so
The car was manufactured in 1992 with a 1.8 DX engine and has a 5 speed manual box.
If you want it shoot me a pm dude.
Rocknrolla said
I have my gearbox out at the moment, my gearbox code is AUG too and my flywheel cover is part number is 068 103 648. Hopefully that should confirm it for ya!
Yes, also if you look at my pic it has that same p/n stamped in the middle.
PM sent Raul
