Engine Code Mystery
(In Topic #119397)
Engine Code Mystery
found my engine code awhile back, but thoght is couldn't be right. I have a 1.6 Golf mk1 clipper, and was pretty sure the engine code had to be RF or EZ, possibly PN.
Anyway, if I'm correct in the positioning of the code (around the third spark plug on the front of the cylinder block, near the fuel resevoir), the engine code is ME.
After a bit of research ME seems to be off a diesel engine; how can this be!? I know my car originally had a 1.8 in it (according to the records), and I think the last guy blew it and replaced it with a 1.6; but is it possible he used 1 1.6 block off a diesel? Does that even work? Confused!
I also seem to remember that lots of blocks even petrols had 1.6D cast in them? :dontknow:
Regards Volkswarren
VOLKSWAGEN VAN GOLF MK2 1.6 Diesel 3/84 - 4/91 JP, ME Eng
Regards Volkswarren
Regards Volkswarren
0261033730 3ME
What does this mean? Is this the engine code and if so, what type of engine is it? 1,6? 1,8? bhp?
Any help is appreciated!
Check out the final picture on this forum:
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=69257&highlight=engine+code
My problem is now that I've found this flat bit where the code should be, if the above forum is correct, it seems that there isn't one there; even after a good clean with a wire brush. Any help? Any other way of finding the engine code?
a clue is a large 1.6 or 1.8 cast into the back of the block, but this isnt that helpdull when you consider that the later 1.6 lump has 1.8 cast into it becasue its based on the 1.8 block with tweaked internals to reduce the cc.
