3 problems with my clocks? can you help ?
(In Topic #142238)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image0559%20CARS.jpg)
![DJ_XJS in the usergroup ‘Regular’ DJ_XJS in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
2nd problem my high beem led light is very dim but works??
3rd problem rev counter needle just drops to 0 somtimes rarely but with a bang from the hand to the dash it somtimes cures it?
good hey
any opinions people of earth? or simple cures?
i know how to take the clocks out and disamble it just not great with wires i have a current tester, the one that has a little bulb in it only
thanks for reading
keeping it mk1
2. change the bulb
3. dash problem or loose connection on the plug to it, could be related to 1
keeping it mk1
Took the clock apart and found a blown bulb for problem 2 well done!! do you know where i can get more from???
I was in the middle of putting some tappets in today and found the the rocker cover i put in a month ago was two wide though the right one and had crumbled off all around the inside!!!!!!!!!!! Jesus i said, so now im thinking the shit has cloged up the oil filter and is restricting oil flow and pressure!!!!!!!! i only put good oil in it october maybe i could strain it ????and just replace the filter ? I recon i might of sussed out problem 1 i dont know it seems very likley to me.
keeping it mk1
you're going to have to have the sump off at least, if you're lucky those bits of gasket are in the pickup and no stuck in the engine somewhere
